Brake Boosters
Old May 9, 2017 | 07:50 AM
Gordonm's Avatar
Gordonm
Default Brake Boosters
There is the stock C3 vacuum canister, big and works fair for performance driving. There is Hydroboost which I have right now. It's reaction time is very strange and gives strange pedal feed back. Could be withthe LS3 pump the pressures are not exactly right. What other brake booster options are people running. I have heard the C6 booster works very well. Anything else out there?
Old May 9, 2017 | 09:11 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Gordon maybe check with Howe PS components and see what they say about your stock pump and Hydroboost setup
Howe Perf
Old May 9, 2017 | 10:23 AM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
A couple years back I bought a used C6 booster in order to see if I could pull some weight off the car. The C6 booster looks a lot like the C3 booster, but it only ended up being about 3 or 4 ounces lighter (not worth all the time and effort to swap it in). I expect that a C6 booster should function just fine in other vehicles, as I've never heard any complaints from C6 owners.
I eventually used an '84 C4 booster on my car. It was half the weight (4# vs 8#) of a C3 booster, and the smaller diameter (compared to later C4 boosters) made it fit well. I'm using a C5 m/c with it, and the brakes are darn firm. Very happy with this combo, performance wise, and weight wise (about 10-11 pounds lighter).
Not everyone's cup of tea, but it worked out well for me.
Old May 9, 2017 | 10:17 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Originally Posted by 69427
...I eventually used an '84 C4 booster on my car. It was half the weight (4# vs 8#) of a C3 booster, and the smaller diameter (compared to later C4 boosters) made it fit well. I'm using a C5 m/c with it, and the brakes are darn firm. Very happy with this combo, performance wise, and weight wise (about 10-11 pounds lighter).
Interesting solution there, Mike. What kind of vacuum is your mill pulling? And, was the '84 booster easier than the dreaded manual conversion? (BTDT, up to it again if necessary, but would rather not.) FWIW, ditching the iron MC either way. TIA
Old May 10, 2017 | 08:17 PM
69427's Avatar
69427
I'll confess I don't recall what the vacuum reading was. The engine is reasonably well behaved (as I've aged I've gradually moved from the heavy car/uncivilized engine combo to the lightweight car/smoother engine combo ), and I've got enough idle speed advance timing to get decent vacuum for the booster.
The C4 conversion was pretty easy. I shortened and threaded the (pedal) pushrod for a clevis to hook to the C3 pedal. I then made a small aluminum adapter to connect the 4-hole firewall to the 2-stud booster. Then it was just a matter of removing about 1/16" of material to oval out the C5/C6 m/c retaining holes to match the C4 booster stud centerlines (why Chevrolet does crap like this that's close, but not the same, aggravates me), and also a slight length adjustment of the booster pushrod that goes into the m/c.
I'll confess again that I'm not familiar with the details of the manual brake conversion.
Old May 11, 2017 | 07:07 AM
Gordonm's Avatar
Gordonm
I figure I'll have to do some mods to any booster I use. The LS 3 has a somewhat aggressive cam but should provide plenty of vacuum for brakes. I have to get back to this car and finish it up.
Old May 11, 2017 | 11:35 AM
Big2Bird's Avatar
Big2Bird
Mike, did you take any pictures of the c4 set up? I have the 81 on a diet, and that sounds great.
Old May 11, 2017 | 11:46 AM
69427's Avatar
69427
Yeah. They're in Photobucket purgatory at the moment, but I'll try to get some new ones pulled out and PM'd to you.
Old May 11, 2017 | 12:55 PM
Big2Bird's Avatar
Big2Bird
Thank you.
Old May 12, 2017 | 10:02 AM
ajrothm's Avatar
ajrothm
I'm not sure what you consider aggressive but...
On my 404" LS, when it had a 226/238* 115 LSA cam, my brakes worked great...just as good as stock..(C5Z)
When I went to the 239/252* 115 LSA cam, it only had 8-9hg of vacuum at idle in gear and the brakes were terrible. I even took it to a dealer to have the whole system flushed/bled/cycled the ABS module etc thinking it was a brake problem... Brakes sucked. Then I put the vacuum gauge on the motor and saw the crap vacuum.
On another LS car of mine, I had a 237/242* on a 113 LSA and the brakes worked fine.
Just throwing it out there. I think I would investigate the hydroboost issue and fix that before going back to vacuum.
Old May 12, 2017 | 11:15 AM
Gordonm's Avatar
Gordonm
Cam specs are 223/231 on a 112 LSA. Should be no problem for vacuum .
Old May 12, 2017 | 01:59 PM
ajrothm's Avatar
ajrothm
Oh yeah, you'll be good with vacuum with that one... Thats a nice lil cam.
Old Dec 2, 2021 | 01:36 AM
JohnRR's Avatar
JohnRR
Thanks for all the replies. I'll try raising the front end up high and cycling the rack back and forth several times.
If that doesn't work, I think I read somewhere there is a brake booster that is smaller in diameter, but has twin diaphragms. I was hoping that one of the forum members has already done this. I am really tired of the constant whine from the hydro boost.
Thanks again,
John
To Brake Boosters
