radiator problems
Old May 9, 2017 | 03:23 PM
Youngvettehunter's Avatar
Youngvettehunter
Default radiator problems
I have a lot of coolent leaks... i should have known that everything was gonna leak because i used a lot of the original parts. so now i have decided to replace the leaking parts instead of "fixing" them. i have a 1968 small block but it has a 1988 350 in it. right now the car has a leaking expansion tank and a leaking radiator. i am not using the heater core at all so i'm wondering if i can replace the radiator with a radiator that has a filler neck on it and get rid of the expansion tank completely? i would of course have to use a recovery tank but will the cooling system work without the expansion tank if i had the other style radiator?
Old May 9, 2017 | 03:38 PM
MelWff's Avatar
MelWff
you can do any style you want but the radiator has to be the same width to fit the radiator support.
Old May 9, 2017 | 04:21 PM
The13Bats's Avatar
The13Bats
There were different style radiator supports 68 was like a leftover from midyears, but having that tank isnt a must if you use the right parts, my 66 was custom, no filler on radiator but rather i had an adaptor that placed the filler on the upper radiator hose,
My 69 has filler on radiator, no tank, i do run a puke tank, and heater has a spin valve to turn it off....
To radiator problems
