Fitech EFI settings
Old May 11, 2017 | 06:51 PM
Sacred Steel's Avatar
Sacred Steel
Default Fitech EFI settings
Hey fellas,
I installed my Fitech Go EFI 4 a couple weeks ago and was wondering what you guys have your loop rate up and down set at. I did the general set up and everything is good except it seems to take awhile for the idle to return when I sit there and rev the motor. I'm pretty sure it's in the loop rate down setting but there isn't much info on that out there.
Old May 11, 2017 | 07:38 PM
Bloodzone's Avatar
Bloodzone
I had the same problem and the loop rate adjustment corrected it. If I remember correctly....Fitech recommends steps of 10 till its good.
Old May 12, 2017 | 04:58 AM
Sacred Steel
Which way should the settings be adjusted? Does lowering the numbers speed up the return to idle time or slow it down. This is one area that I can't seem to fine any solid info on for some reason.
Old May 12, 2017 | 05:40 AM
Bloodzone's Avatar
Bloodzone
My car is still in paint so I can't check and be 100% correct but I think you increase loop rates to stop a hanging idle.
Facebook has a "Fitech Owners Group" that people say has some good info. Could be worth joining if you do the facebook thing.
To Fitech EFI settings
