need help with timing
I have set the timing per Lars excellent papers. I have 36* mechanical advance and with a VC1853 vacuum can, I have about 31* at idle and 51-52* at higher rpm. Here's the problem, I have a nasty part throttle jerk/chug up to about 2500 rpm, then it's fine. No knock, just the jerk.
Reading Lars paper, he says this could be the result of too much vacuum advance at a lower rpm.
I am using the gold MRG springs but I still get all the mechanical advance to 36* coming in around 1500 rpm instead of all in by 3000 rpm. I'm thinking this coupled with the vacuum advance is too much advance at a lower rpm and is causing my issue?
Do I need to somehow slow down the mechanical advance? Heavier springs? Lighter weights?
I can disconnect and plug the vacuum advance, drive it and the problem all but goes away.
Chased this for two days now and I am stumped.....and somewhat frustrated
I just sorted my timing out too so maybe a suggestion or two could help.
First try and back off the initial timing a couple degrees and take a power run. If this solved the problem leave well enough alone.
Second make sure the weights are moving freely after the spring swap and not binding during advance.
Also miti vac the new advance can. Make sure you have the unit fully advancing 2* below the initial. Your base timing seems too high.
Marshal
I have set the timing per lars excellent papers. I have 36* mechanical advance and with a vc1853 vacuum can, i have about 31* at idle and 51-52* at higher rpm. Here's the problem, i have a nasty part throttle jerk/chug up to about 2500 rpm, then it's fine. No knock, just the jerk.
Reading lars paper, he says this could be the result of too much vacuum advance at a lower rpm.
I am using the gold mrg springs but i still get all the mechanical advance to 36* coming in around 1500 rpm instead of all in by 3000 rpm. I'm thinking this coupled with the vacuum advance is too much advance at a lower rpm and is causing my issue?
Do i need to somehow slow down the mechanical advance? Heavier springs? Lighter weights?
Chased this for two days now and i am stumped.....and somewhat frustrated
I could find it on my machine, but over the net all I can suggest is see if the weights are stock,
Measure your idle vacuum, and cross it to Lars HEI vacuum can chart.
At that level all of your mechanical advance would be present plus all the vacuum unless you're full throttle.
Slow down the mechanical with stronger springs would be my first attempt. If that cant get it then yes you can reduce the weight of the weights. If they are stock weight I can't see why they would be too heavy though.
Maybe they have been altered at some point in the past.
It's possible someone may have even altered the shape of the weight which would change the timing advance curve.
Throw up a pic and maybe we can see if they look stock.
Anyway, this is what I've got. Anything not look right?
I'll flip the weights around and go back to the gold springs next. Thanks.
They are not upside down.
I was going to drive it this evening but the time got away from me. Tuesday before I can test it now. I'll report back.
Thanks, everyone, for the help. This place rocks.
It wasn't timing.Replaced #5 and #6 plug wires with my old wires. Problem solved. One boot had a hole burned almost all the way through from arcing to the header. Supposed to be good wires, too. Guess I'll buy a set of ceramic boot wires now.
Thanks for all the help.
