TRW Camshaft
Old Sep 28, 2002 | 04:14 PM
Saenger's Avatar
Saenger
5th Gear
Default TRW Camshaft
Hi !
I'm looking for information about TRW camshafts (duration etc.). I didn't found anything at http://www.trw.com and http://www.summitracing.com .
Do you know a website where I can find these informations ?
Thanks and best regards,
Saenger
Old Sep 28, 2002 | 05:11 PM
Blues77's Avatar
Blues77
Default Re: TRW Camshaft (Saenger)
I did a search for you and couldnt find anything either. TRW makes camshafts?? :confused:
Old Sep 28, 2002 | 06:21 PM
jackson's Avatar
jackson
Hi !
Saenger
Saenger:
Please post the summit part number and what engine (chevy, sbc,BBC, ford 302 etc) it is for . Then I can look in my TRW book for the cam specs. Yes TRW Speed Pro make cams ... lots of them. TRW makes replacement internal engine parts for virtually everything inside a chevy or ford etc. They also make satellites ... those in geosynchronous orbit above your head!
OR ... If you have a TRW or Speed-Pro camshaft part number ... post it & I will post the specs.
Speed-Pro's Tech phone USA (800-325-8886)
TRW is also known as Federal Mogul and also Speed-Pro and also Sealed Power ... try this link to the group ... there's no catalogs there but it may help http://www.federal-mogul.com/aftermarket/default.asp ... for instance, if you wanted a "TRW" forged piston, you'd find it listed as a Speed-Pro ... same thing if you wanted a performance cam or roller rockers (yes they have those too). TRW (& the group) are undergoing restructuring so divisions will be moved to & fro.
[Modified by jackson, 5:30 PM 9/28/2002]
[Modified by jackson, 5:36 PM 9/28/2002]
[Modified by jackson, 6:20 PM 9/28/2002]
Old Sep 28, 2002 | 11:48 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
post the cam# and i will look it up for you :chevy
Old Sep 29, 2002 | 06:16 PM
Turbo-Jet's Avatar
Turbo-Jet
Default Re: TRW Camshaft (clem zahrobsky)
Really? Where is the number located? Mine was rebuilt with TRW lifters, so I would assume it has a TRW cam too. I would really like to ID it before I go to the dyno.
Old Sep 29, 2002 | 06:38 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Default Re: TRW Camshaft (Turbo-Jet)
Lot's of cam grinders sell TRW (and other's) lifters as their own and a lot of builders don't buy their cams and lifters as a set so I wouldn't assume that the cam is a TRW also. If you have the receipts from the rebulid, or can ask the builder, there may be a part number that can help. If the engine was rebuilt to stock specs, it's likely that the cam is stock or close to stock. While it's possible to determine the specs of a cam that's installed, the process is pretty involved. IMO, probably not worth the trouble. It would be nice to know what you have, expecially if you are planning to replace it. Without knowing the specs, you won't know how much bigger or smaller a cam you want.
Old Sep 30, 2002 | 03:47 AM
Saenger's Avatar
Saenger
5th Gear
Default Re: TRW Camshaft (jackson)
Hi !
Thank you all for the help. Well, my car has a 82' Corvette Crossfire Engine. The Garage replaced the cam by a new one from TRW. I think they said the type of cam is a "207" or "270"........ I hope that helps....
Thank you very much and best regards,
Saenger
Old Sep 30, 2002 | 02:21 PM
jackson's Avatar
jackson
Hi !
Saenger
Saenger:
Ask the garage "what is part number?" of the TRW cam ... maybe they have that in their purchasing records. Also ask "what kind of cam?" ... such as hydraulic flat tappet (the '82 came with this type cam), hydraulic roller (maybe) etc. Those numbers 207 & 270 don't help me find the cam ... but someone else here may be able to help with just those numbers. If that refers to duration, 207 or 270 would indicate a rather small cam ... and I don't see one in my TRW Speed Pro book with either duration. Two typical part numbers are like these: CS1062R and CS1095R ... both are hydraulic flat tappet cams.
To TRW Camshaft
