cam question on 1982 corvette
Old May 14, 2017 | 10:46 PM
bensons82's Avatar
bensons82
Default cam question on 1982 corvette
alright this past winter i tore my engine apart and rebuilt it i of course did some upgrade and should run good but it takes forever to take off till about 3400 rpm for it to actually take off like it should. today i had a buddy check it out for me and he checked the vacuum on it and its making around 12 vacuum which i guess it should be 18? said i need to replace the cam i put in it because its to big. i put a lunati voodoo cam part number 10120702LK i thought that was right but i guess i was suppose to install the lunati voodoo part 10120701LK there is just a little bit of a difference but i did also put 1.6 rocker arms on it which made it worse so my question is should i take my cam out replace it and replace the 1.6 rocker arms or is there away to make what i have already work? does anything need to be done to the computer? also what else was done to the car i put full length headers on it and new edelbrock estreet aluminum heads part number 5089 and also ported the intake and deleted the egr any help would be greatly appreciated
Old May 14, 2017 | 10:51 PM
TimAT's Avatar
TimAT
If you can find a company that will custom burn a PROM for your computer it could be made to work. I had one made for a Camaro several years ago. My customer had someone put a cam in that was like yours- low idle vacuum.
Old May 15, 2017 | 02:43 AM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
What is the rest of the build, pistons, heads etc... Either cam would work depending, but the 10120701LK would be a better choice, again depending on the rest of the build. Are you running the stock ECM on your 82? 15 would be the absolute lowest you would want to go for vacuum IMO just as a safety issue with power brakes and that would be iffy IMO. 18 or more is good. The killer for a cam change on a stock or somewhat stock CF is the duration @.050, "straying too far from stock" is bad and will cause issues. Your current cam is a bit much, but the other cam that you should have used would have been much better. Also, again IMO, you should go roller cam vs. flat tappet. You will not have to worry about the motor and oil with a roller. Post up the rest of your specs.
Old May 15, 2017 | 04:30 AM
Sunracer's Avatar
Sunracer
bumping up the initial timing will help
Old May 15, 2017 | 06:11 AM
bensons82's Avatar
bensons82
the piston as stock and the heads are edelbrock estreet aluminum heads part number 5089 yes it still has the stock ecm that hasn't been touched what's the difference in roller vs flat?
Old May 15, 2017 | 06:19 AM
bensons82's Avatar
bensons82
Also my buddy that looked at my car said I should switch the cam to a Truck RV cam for the low end
Old May 15, 2017 | 07:49 AM
Tiger Joe's Avatar
Tiger Joe
you can't change a cam without retuning the computer. since that's not like a modern computer, you need someone to burn you a chip to replace to help the car run better.
I don't know much about the limits of the crossfire computer, but you should find someone knowledgeable about these types of computers and see if you can have a chip burned to match your current cam.
EDIT: your lack of low end power has nothing to due with "need a truck/RV cam" it has to due with the computer still fueling like you have a stock cam, and you fuel requirements have changed.
Old May 15, 2017 | 07:51 AM
sparky77's Avatar
sparky77
Take the 1.6 rockers out and install 1.5s it will help get more vacuum.Lunati voodoo cams are built to have good vacuum .
Old May 15, 2017 | 10:34 AM
terry82's Avatar
terry82
start with 1.5 rockers and see if that helps.I also would check to make sure you don't have a vac leak.
Old May 15, 2017 | 10:57 AM
bensons82's Avatar
bensons82
I was going to just change them and see if that made the difference but the lift on the cam in it is 219/227 and I guess with the stock computer you can't go over 220 and the other cam is 213/219
Old May 15, 2017 | 11:45 AM
v2racing's Avatar
v2racing
It's never going to run good unless you recalibrate the ECM. Anything that changes the volumetric efficiency of the engine will throw the calibration off. You have heads and a cam change.
You need to get someone who is good with those ECM's to burn a chip based on your build, go to an aftermarket fuel injection system, or go to a carb and intake.
Mike
Old May 15, 2017 | 11:53 AM
terry82's Avatar
terry82
this is the cam I use http://www.compcams.com/Company/CC/c...x?csid=84&sb=0 stock computer.16-17 vacuume.ported intake.
Old May 15, 2017 | 12:11 PM
Fast81's Avatar
Fast81
Bensons - you have ALOT of things going on here with your build. FIRST, the ECU cant handle the cam you picked. SECOND, the E-street heads with 64cc chambers take your DCR above 10.0 which the ECU also cant handle. THIRD - If your Xfire setup isn't in top notch shape, it'll be pressed to feed this combo with the stock fuel pump. FOURTH - your ported intake will still be the choking pt even after you solve 1-3 above, think Renegade intake.
Hope this sends you in the right direction
Fast81
Old May 15, 2017 | 12:47 PM
v2racing's Avatar
v2racing
I missed the headers and the ported intake. You are way beyond what the ecm and stock fuel pump can feed, just as Fast81 has stated.
I would really look at going with an aftermarket fuel injection system. You at least are going to have to upgrade your fuel pump and have a chip burned, minimum. You still might have issues.
Mike
Old May 15, 2017 | 12:59 PM
MelWff's Avatar
MelWff
The first number you listed it clearly states in the description Not computer compatible
The second number you listed it clearly states it is a Marine and Towing application.
This is the only Lunati Voodo that is for your computer controlled engine for street usage, 10120700LK
https://www.summitracing.com/parts/l...make/chevrolet
Old May 16, 2017 | 09:38 AM
bensons82's Avatar
bensons82
Fast81
would it be a better idea to get the renegade intake or switch it to another efi I have been told to switch it to a tune port system but didn't know if it would be worth it also I habe no clue how to get this computer upgraded I've heard people upgrade the 82 ECM others put in 84 Corvette ECM in it and put a chip in it or some people get ECM from later TPI cars and make them work for the crossfire I just have no clue on how to do all of that
Old May 16, 2017 | 09:42 AM
bensons82's Avatar
bensons82
I got the cam 10120701LK from a member on here that used the same cam in his 82 crossfire and said it worked for him I just accidentally order the wrong one I ordered the one right above it 10120702 LK
To cam question on 1982 corvette
Old May 16, 2017 | 10:00 AM
terry82's Avatar
terry82
I would go to crossfireinjection.net
Old May 16, 2017 | 12:30 PM
bensons82's Avatar
bensons82
they shut down the end of last year
Old May 16, 2017 | 01:13 PM
Kacyc3's Avatar
Kacyc3
dont forget the C4 section here or try
www.thirdgen.org
if you want to learn to tune check out
www.gearhead-efi.com
