My first trouble post, temperature sending unit specificed does not fit?
Old May 15, 2017 | 11:12 PM
ET_Ferguson's Avatar
ET_Ferguson
2nd Gear
Default My first trouble post, temperature sending unit specificed does not fit?
Hi All! I'm happy to be part of this great community. I've been lurking for awhile and reading through tons of great resources on here about my baby, a 1979 L82. I've found all of my answers already by searching them out (don't you love it when someone's been a part of a forum before and doesn't just post a question that's already been answered without searching first)! However, I've come to a tough spot that I need help on.
I looked up the replacement temp unit for my car because the fin broke off and my gauge is dead. Several online corvette stores are telling me it's GM part #8993372. So I called my local Napa (I'm in Canada) and they gave me a generic replacement here: https://www.napaonline.com/en/p/ECHTS6641
Problem is I tried it over the weekend and my old unit is a) not imperial (between a 7/16 and 3/8) so I had to use a crescent wrench to get it out and b) the thread diameter is way smaller on the new unit! Now I'm worried, do I have the wrong part or do I have a different 350 engine in my car that I never knew about!
Thanks in advance for any help
Elliot
Old May 16, 2017 | 12:45 AM
Frank_Nesta's Avatar
Frank_Nesta
Take your old one in to Napa and they will match it.
Old May 16, 2017 | 04:30 PM
bradleyb66's Avatar
bradleyb66
What was the location of your sender (head or intake manifold)? Here is a thread where Tooonz had a similar problem, but the sensor he was replacing wasn't in the 'standard' position (in the head between spark plugs 1 & 3).
https://www.corvetteforum.com/forums...t-reading.html
Old May 16, 2017 | 05:11 PM
ET_Ferguson
2nd Gear
No see that's the weird part, mine is in the standard position, and appears exactly as pictures in my Hayne's manual. Really stumped here.
Old May 16, 2017 | 05:22 PM
bradleyb66's Avatar
bradleyb66
My 79 is an L48, but I think the L82's had an electric auxillary fan. Maybe you bought the sender for the fan control, and not the one for the temp gauge?
Old May 16, 2017 | 06:01 PM
bradleyb66's Avatar
bradleyb66
OK, the parts houses that I looked up the temperature sender on (Napa and O'Reilly) seem to list a 3/8" sender for 79-80 vettes, but I think it should be a 1/2" sender. And, according to Lectric Limited, it looks like GM 8993372 is actually 1/2" thread. I agree with Frank_Nesta - take the sender back to Napa and have them match it.
Old May 16, 2017 | 08:38 PM
C3 4ME's Avatar
C3 4ME
Bradley666 might be on to something. 79 L-82's with air had a factory electric fan as a back up, and had a sensor for the fan mounted in the passenger cylinder head btwn 6 and 8 cylinder. They might have given you the fan temp sensor, not the gauge temp sensor. I'm not sure of the thread size on either though.
Old May 18, 2017 | 03:39 PM
Crimson Thunder's Avatar
Crimson Thunder
This is my Bubba fix for the problem. All parts are from Home Depot and cost about $3.00. This was supposed to be a temporary fix but I've had it like this for about 12 years.
Old May 19, 2017 | 02:17 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The original sender was 1/2 x 14 N.P.T. for the temperature gauge. There is a sender on L-82 cars with aux. cooling mounted on the passenger side that is smaller.
Willcox
Old May 19, 2017 | 03:29 PM
bradleyb66's Avatar
bradleyb66
Willcox
Do you have any idea why the national parts stores (Napa, Autozone, O'Reilly) all list a 3/8"x18 sensor? None of them listed two sensors, or showed anything different for the fan controller.... I do see a 1/2"x14 sender listed on RockAuto...
Old May 19, 2017 | 09:31 PM
0Willcox Corvette
Former Vendor
The same reason when you get a heater core from an aftermarket company that is aluminum... or why they sell you rebuilt calipers for the 2 times the price you could buy stainless steel calipers from us... or the same reason they sell aftermarket clutch fans that won't fit...
Aftermarket companies don't deal with this on a daily basis, they only go by what the catalog say's.. Which as you can tell can be deceiving.
I have the correct sender at this link: https://willcoxcorvette.com/79-80-te...e-sending-unit
Old May 20, 2017 | 12:47 AM
bradleyb66's Avatar
bradleyb66
I'll probably have to order one with my next order, just to have in my toolbox in case I ever need one.
To My first trouble post, temperature sending unit specificed does not fit?
