running 200 degrees
Old Sep 28, 2002 | 08:17 PM
madvette74's Avatar
madvette74
Default running 200 degrees
i am running around 200 degrees, my temp sender is located in the intake, i have a electric fan, but it does not turn on, i am wondering if the temp is acuurate,
Old Sep 28, 2002 | 08:22 PM
YoNni22's Avatar
YoNni22
Default Re: running 200 degrees (madvette74)
Mine is running a little higher. It recently ran at around 180 but I change the radiator cap from 7 psi to 16 psi. It dips below 200 when I'm on the highway but goes like 215 when I'm stuck in traffic.
Old Sep 28, 2002 | 08:47 PM
kingdavidrules's Avatar
kingdavidrules
gotcha both beat . my car was running 240 - 250 degrees . i changed the radiator to a 4 core , that cut it down to about 220 - 240 . i just recently put in an electric fan 2200cfm and was told to take my engine fan off as it wasnt needed . the car now runs in traffic at 220 - 240 :lol: so the way i see it , the more cooling the better , the engine fan goes back on tomorrow and the electric fan only gets used durring traffic conditions . which is when you need it the most .
Old Sep 28, 2002 | 08:54 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: running 200 degrees (kingdavidrules)
Man you guys a sure running hot!
I run 210 or so when it's 90+ out. When it's cool I'm down to 180...
Old Sep 28, 2002 | 08:55 PM
78Vette-SA's Avatar
78Vette-SA
When I got the car I later found out the rad was shot. I yanked it and dropped in a Griffin along with a high-flow waterpump. It's never gone barely over 200 even with the A/c on in 90+ heat and traffic.
If you're running at 200, I'd be happy! :lol:
[Modified by 78Vette-SA, 7:56 PM 9/28/2002]
Old Sep 28, 2002 | 09:07 PM
jerryp58's Avatar
jerryp58
200 is NOT bad, especially if it has a 195 thermostat in it. When was the last time you did a flush & fill?
I am in the process of a coolant flush & fill (I have a rant/question thread out).
I was surprised to see that I had a 180 thermostat in there: I forgot I did that. I guess it was open all of the time because I was running about 195 after my last flush & fill (about 2-3 years ago). It had slowly crept up to about 205.
I have 100% water in it now and it sitting about 180-185. I guess it'll go up a bit when I put coolant in it tomorrow.
Old Sep 29, 2002 | 08:08 PM
madvette74's Avatar
madvette74
Default Re: running 200 degrees (jerryp58)
my radiater was hot tanked and flow tested, about a year and a half ago, i only put 650 miles on the car, but i guess 200 degrees is not that bad..
Old Sep 29, 2002 | 09:51 PM
Paul L's Avatar
Paul L
I would say it is normal. The boiling point of water is 212F. Add a little antifreeze and a 15psi rad cap and the system will tolerate much higher temps.
Old Sep 29, 2002 | 10:07 PM
SLICKMAN's Avatar
SLICKMAN
Default Re: running 200 degrees (paul79)
Mine is all stock and I changed the therm stat over to a 160. Also took out the clutch fan in put a semi-flex 18 inch fan in. It runs at 160 - 170 at any speed so far..
To running 200 degrees
