76 flooded, dried out now no spark
Old May 18, 2017 | 04:07 PM
lestro's Avatar
lestro
Cruising
Default 76 flooded, dried out now no spark
my son's 76 was caught in a flood, we dried it out, got the water out of the engine. It cranks fine but no spark. The hei distributer is clean and dry. Where is the fuse panel for this thing and how can a normal person get to it?. any help and tips would be appreciated.
Old May 18, 2017 | 04:16 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The fuse panel is under the dash above your left foot if you were sitting in the car.
Easy to get to is a moot point.
Old May 18, 2017 | 04:25 PM
lestro's Avatar
lestro
Cruising
thanks for your reply, is there any panels a person can take off to enen see the fuses?
Old May 18, 2017 | 04:39 PM
doctorgene's Avatar
doctorgene
I think that you can get at it better if the dash on the driver side is out. It's not that big of a job, if you take your time. I think that you would need to blow out all connections inside & out & shoot a coating of W/D 40 on all of it. Lots of luck. Gene
Old May 18, 2017 | 04:41 PM
chazde3's Avatar
chazde3
No panels, you are just going to have to lean in under the steering wheel and dash to access it. Doing some of the under dash work on these old cars practically requires a contortionist.
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome.
Do you have a HEI distributor?
With the key in RUN or START do you have 12volts at the distributor?
If yes then confirm that the module and the coil are good.
Old May 18, 2017 | 05:23 PM
TimAT's Avatar
TimAT
Take your head off and install it backwards.
Seriously, check for 12v at the BAT terminal on the HEI. If that's good, disconnect the TACH wire from the cap and try it. If that works, you have a tach/tach filter problem. Still no start, hook a 12v terst light between the tach terminal and a good ground. Crank the engine. If the light flashes, the module and pickup coil are good. No flash, it's time to dig. Either the module died or a broken wire to the pickup. Or both.
Old May 19, 2017 | 08:10 AM
lestro's Avatar
lestro
Cruising
Thanks for all the replies, I will check the hei for battery, if not I have a camera that might work to see the fuse panel. thanks again, Les
Old May 19, 2017 | 09:59 AM
blue by you's Avatar
blue by you
you got the water out of the engine, how bad was the flood
Old May 19, 2017 | 06:30 PM
lestro's Avatar
lestro
Cruising
all the way over the top
Old May 19, 2017 | 07:51 PM
sunflower 1972's Avatar
sunflower 1972
Oh boy, that's NOT GOOD. Your dealing with a 40 year old sports car. Water gets EVERYWHERE. All I can say is good luck and I'll say a prayer for you.
Old May 19, 2017 | 09:04 PM
lestro's Avatar
lestro
Cruising
thanks, I'll take all the prayers I can get.
Old May 19, 2017 | 09:39 PM
TimAT's Avatar
TimAT
If water was over the top, you did change the oil and remove all of the spark plugs and THEN turn the engine over?
Old May 20, 2017 | 08:46 AM
lestro's Avatar
lestro
Cruising
yes
Old May 20, 2017 | 01:55 PM
JayRay's Avatar
JayRay
I wish I could! That would make things so much easier to work under the dash.
Old May 20, 2017 | 01:57 PM
dmaxx3500's Avatar
dmaxx3500
did you pull off the cap,wires,rotor,and replace them?
Old May 20, 2017 | 02:28 PM
lestro's Avatar
lestro
Cruising
I did pull the cap coil rotor and inspect them and test with an ohmmeter as best I could, I did however, find corrosion on one lead of the ignition module to the star like thind (whatever you call it) that I beleive is tjhe problem. when it stops raining I'll clean it up and try it
To 76 flooded, dried out now no spark
