Will not start, but almost!!!
Old May 18, 2017 | 05:32 PM
Red Hot 71's Avatar
Red Hot 71
Default Will not start, but almost!!!
Top dead center on compression stroke & rotor lines up w/#1 spark plug wire. New distributor cap & rotor. MSD ignition system. Could the coil or the box be the problem? Please help! Could it be plugs or wires? Both are new.
Old May 18, 2017 | 05:34 PM
TimAT's Avatar
TimAT
Is it an MSD cap & rotor? When I put an MSD distributor in my 69, no start. Plenty of spark in, but nothing out. Swapped back to the original cap and rotor and it runs. Been a while back.
Old May 18, 2017 | 05:49 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you need #1 spark at the right time, do you have spark ?
after that, you need fuel and air. test for spark at plug wire. carefully !
Old May 18, 2017 | 06:07 PM
blue427's Avatar
blue427
Advance the timing,sounds like you're on 0,should be about 6 or 8 degrees before top dead center to start.
Old May 18, 2017 | 09:31 PM
rebel542's Avatar
rebel542
Sounds like the ballast resistor is bad. As long as the starter is engaged it starts but as soon as you turn the key back to run it shuts off. Right?
Old May 18, 2017 | 10:21 PM
TOM B1's Avatar
TOM B1
Did your vette come with a points distributor?
Is your new distributor A points style MSD or a Electronic MSD distributor.
If your vette was built with a points dist. and you replaced it with a electronic style then you must NOT use a ballast resister. Check the volts at the dist. you must have 12V or higher. If you only have 7 to 9 volts then you must run a new keyed Ignition wire with 12 volts.
Only points had this low voltage to not burn the points.
Old May 19, 2017 | 07:07 AM
Red Hot 71's Avatar
Red Hot 71
I bought the car (5) yrs. ago just as it is. Ran great. Has MSD pointless ignition w/coil & box. Thought cap & rotor looked bad so I replaced them w/OEM. Did not want to wait to order another MSD. Still the same thing. I am on TDC/0. That may be the problem. Will check tonight. #'s indicate it is a 1982 block in a 1971 Stingray. So I imagine it came originally w/HEI ignition. Good things to check, Thanks to those that replied.
Old May 19, 2017 | 12:19 PM
69Vett's Avatar
69Vett
71 did not have HEI from factory, points or transistor ignition.
Old May 19, 2017 | 01:18 PM
OldCarBum's Avatar
OldCarBum
Did you make any mods besides the new cap and rotor? If not it sounds like the cap and rotor you installed will not work with the MSD. Purchase an MSD replacement cap and rotor and see if the problem goes away.
Old May 19, 2017 | 04:01 PM
Red Hot 71's Avatar
Red Hot 71
Do not know what distributor type came w/the motor. It is an 82 clock, car is a 71. As far as swap outs go, I changed distributor cap & rotor after it would not start w/original MSD stuff. Before that I replaced plugs w/NGK plugs & MSD 8.5mm wires. Firing order is correct.
Old May 19, 2017 | 05:01 PM
Red Hot 71's Avatar
Red Hot 71
Default Will not start. But almost!
Meant to say block not clock!
Old May 19, 2017 | 05:26 PM
Red Hot 71's Avatar
Red Hot 71
Just got the sucker to fire off & start. Think my problem was as Blue 427 suggested, I was @ 0 & needed to be @ 8 degrees BTC. Runs rough, but it is comforting to hear it run. Again, Thanks for all who responded & offered suggestions.
To Will not start, but almost!!!
