must core support come out to pull engine?
Old Sep 29, 2002 | 12:38 AM
71roadster's Avatar
71roadster
Default must core support come out to pull engine?
I am finally ready to pull the engine and am wondering if I have to pull the radiator and core support out to get the engine out. I plan on pulling the tranny with the engine.
Chris
Old Sep 29, 2002 | 12:48 AM
C3 Shark Tank's Avatar
C3 Shark Tank
Default Re: must core support come out to pull engine? (71roadster)
I pulled mine with the support still in, put it back as well the same way. I did end up taking the support out to sandblast and paint it, it's a good time to do so and worth the effort.
Old Sep 29, 2002 | 05:19 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
It makes it a HECK of a lot easier with the support out, especially since the trans is coming out too. Chuck
Old Sep 29, 2002 | 05:46 AM
Fleetwood's Avatar
Fleetwood
Take out the radiator & support,gives you a lot more room to move the engine & gearbox forward.
Old Sep 29, 2002 | 12:52 PM
afun'71's Avatar
afun'71
Bingo on pulling the core support since your are pulling tranny as well. Need to support nose though. Core support helps support the nose. Use 2x4s to support just as precaution.
Great looking pictures! I am repainting my '71 back to original Bridgehampton blue. Noticed your side vents look a little different. Did you do something special to them or is it just the picture?
Also, good looking engine. What bolt ons did you use?
Old Sep 29, 2002 | 01:01 PM
NHvette's Avatar
NHvette
Default Re: must core support come out to pull engine? (afun'71)
If you leave it in, DEFINITELY get one of the load levelers. They have a crank
that allows you to adjust the tilt of the engine/tranny as it is raised.
Anyone have a picture of this ?? There was a post a couple weeks back.
Good Luck
:seeya
Old Sep 29, 2002 | 07:54 PM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
yes, definately support the nose. the core support adds to the structural integrity of your front end....i used 2x4's like afun '71 suggested.
'74 L-48 4 speed
To must core support come out to pull engine?
