Help with A arm rebuild???????
Old Sep 29, 2002 | 04:38 AM
chadman's Avatar
chadman
Default Help with A arm rebuild???????
I'm installing poly bushings in the front of my vette. Any tips on gettin the new sleeves in? Pounding with wood block hasn't worked very well! Anyone found a trick?
Old Sep 29, 2002 | 06:03 AM
78pace's Avatar
78pace
Default Re: Help with A arm rebuild??????? (chadman)
when i did mine took them to a shop and had them pressed in :smash:
Old Sep 29, 2002 | 08:54 PM
Duke94's Avatar
Duke94
You need a hydraulic press or a BIG vise.
Old Sep 29, 2002 | 10:26 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I used a couple large C-clamps and forced the little boogers in. It wasn't easy, and you can easily distort the arms if not done correctly. I'd try a dealer or machine shop that might have the special tool that presses them in. A picture of the tool is shown in the GM service manual. :smash:
Old Sep 29, 2002 | 10:34 PM
jackson's Avatar
jackson
If you're talking about the outer shells??? Are yours in good shape? If so, why replace? When I did my with energy suspension poly, I just juggled the old rubber out and replaced only the inner sleeve and the poly bushing ... works great. Most of the old rubber will pull out ... I had to use a about 1-1/8" hole saw to ream out some rubber. No vise, no press, ... & no stress on the control arm!
PS ... the inner sleeve is split-design. Once you've got most of the old rubber out, take a thin screwdriver or chisel blade and tap into the split ... it'll open right up and you can easily slide the sleeve off the shaft.
[Modified by jackson, 9:43 PM 9/29/2002]
Old Sep 30, 2002 | 05:20 AM
chadman's Avatar
chadman
Default Re: Help with A arm rebuild??????? (jackson)
I already removed the outer shell on one side of the car. Now have trouble gettn the new ones in.
Old Sep 30, 2002 | 06:02 AM
randy814u's Avatar
randy814u
I broke my big vise doing the 85, so now I have to do the 78.
First order of business was to buy a really big vise.
Works great.. :seeya
Old Sep 30, 2002 | 08:08 AM
76-L82's Avatar
76-L82
I have done Many, from 64 El Caminos-76 L82 Corvette.
Put the complete bushings w/Collors in the freezer over night(Or till you need them).
Emery clothe all burrs and rust off of the A-arms Eye(Where the Collor goes into.
Put bearing grease on the A-arm Eye and the collor and press it any way you can, you will think this is too easy, because frozen metal contracts and the arm is at room tempature out outside in the sune it is more expanded..
Old Sep 30, 2002 | 08:48 AM
Ybnormal's Avatar
Ybnormal
This is the only way I found to do it.
www.angelfire.com/al/swhite7/engine.html
YBNormal...drive a vette
Old Oct 1, 2002 | 08:23 PM
john V. zemba's Avatar
john V. zemba
Default Re: Help with A arm rebuild??????? (Ybnormal)
I used a press, but they tell me a good c-clamps works
Old Oct 1, 2002 | 09:15 PM
GTR1999's Avatar
GTR1999
Default Re: Help with A arm rebuild??????? (76-L82)
I have a set of rubber bushings in the freezer for almost 6 months now! :crazy:
Gary
Old Oct 1, 2002 | 09:22 PM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: Help with A arm rebuild??????? (gtr1999)
Gary
Freezer burn :crazy:
To Help with A arm rebuild???????
