Bleeding Brakes
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
None of them as long as you didn't take the line loose. If you just replaced the rotors the brake fluid system wasn't breached.... thus no need to bleed.
did you struggle with the pistons trying to fit the caliper back over the rotor. If so they may have sucked in air.
