383 Stroker Cam Selection
Old May 24, 2017 | 04:06 PM
ykf7b0's Avatar
ykf7b0
Default 383 Stroker Cam Selection
I recently spun a rod bearing in the factory numbers matching L-48 350 and ruined the crank. The engine needed .030 over bore to clean up and I've opted to go with a 383 stroker kit. I also have factory GM 1999 062 L31 Vortec heads that I will be using and will be getting the lift issues taken care of by my machinist. My 76 Vette is an a/c car with power brakes and I know I'm limited with my camshaft selection due to needing plenty of vacuum. I have headers with 2.5 inch exhaust and I wish to stay with my stock torque converter. I would like to get your recommendations on a great cam selection to go with my components.
Old May 24, 2017 | 05:09 PM
StraubTech's Avatar
StraubTech
223/235
108 LSA
Makes 11" of vacuum.
Old May 24, 2017 | 06:24 PM
NewbVetteGuy's Avatar
NewbVetteGuy
I could've sworn I heard a guideline to just figure out the attributes you want from your cam and use the typical SBC 350 guidelines for duration and just add 10 degrees for a 383.
Straub - any feelings on the SUPER simple guideline?
Adam
Old May 24, 2017 | 06:56 PM
ykf7b0's Avatar
ykf7b0
Originally Posted by StraubTech
.510/.510
223/235
108 LSA
I could be wrong on this but it is my understanding that the Vortec heads are a little weak on the exhaust side and this has me leaning toward a split pattern profile with more lift and duration on the exhaust side.
Old May 24, 2017 | 08:44 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Don't need more lift. Vortec heads hit the wall at 520 lift. 12 degrees extra exhaust duration is plenty of split.
Old May 24, 2017 | 08:45 PM
v2racing's Avatar
v2racing
The cam Chris recommended already has 12 more degrees on the exhaust side. More lift on the exhaust isn't going to gain you anything.
Mike
Old May 24, 2017 | 10:52 PM
drwet's Avatar
drwet
My 383 has 222/222 hydraulic roller cam. Plenty of vacuum and torque is good. If I were to do it over, I would probably go with a little more cam, and maybe consider split duration. I think the engine could handle it.
Old May 25, 2017 | 06:56 AM
ykf7b0's Avatar
ykf7b0
I would go roller if I had the budget for the set up so it has to be hydraulic flat tappet.
Old May 25, 2017 | 10:41 AM
ykf7b0's Avatar
ykf7b0
I'm forever the conservative and I'm currently looking hard at Howard's 269/279 215/225 .455 .465 with 112 LC. Again, I have a stock converter, a/c, and power brakes. What do you guys think? Too conservative????
Old May 25, 2017 | 11:09 AM
BKbroiler's Avatar
BKbroiler
Too conservative, based on my experience. I had a flat tappet hyd cam in my 383, with 218/224 duration. I would get some detonation at part throttle going up hills etc. Switched to a roller with 225/232 duration, and no more detonation.
Old May 25, 2017 | 03:08 PM
ykf7b0's Avatar
ykf7b0
Another choice in question is an Elgin 282/294 216/228 @ .050 .453/.480 112 LC. ???
Old May 25, 2017 | 08:12 PM
drwet's Avatar
drwet
Too conservative for an engine that size. I would be looking in the 225-230 range on the intake, and 230-240 on the exhaust. 110 LSA is about right.
Old May 26, 2017 | 11:45 AM
ykf7b0's Avatar
ykf7b0
Another concern I have is the need for a small base circle cam if I go large. Your thoughts?
Old May 26, 2017 | 12:03 PM
Kacyc3's Avatar
Kacyc3
go with 225ish/235ish @.050 and as much lift as you can with your heads, if you have any thoughts about adding efi later get a 112 LSA.
I have a 234/244 .489/.510 112 in my 406 with efi and it has lots of low end and pulls great to 6k here is how mine idles
Old May 26, 2017 | 09:46 PM
drwet's Avatar
drwet
I do not have a small base circle cam in mine. In fact I was unaware that small base circle cams existed back when I built my engine. I did know that I had to check the clearance between the cam and the connecting rods, which I did, but there was no problem.
Old May 27, 2017 | 11:19 AM
cv67's Avatar
cv67
St. Jude Donor '05
Straub has already done the homework on this his recommendtaions are about as good as it gets. 215@050 will act and sound stock on a 383..you will probably wish youd have gone bigger.(will still run good though)
Old May 28, 2017 | 10:37 AM
ykf7b0's Avatar
ykf7b0
The 11" of vacuum bothers me. I'm thinking I'll have a hard brake pedal.
To 383 Stroker Cam Selection
Old May 28, 2017 | 11:57 AM
C3 Stroker's Avatar
C3 Stroker
11" of vacuum will be fine. I've had 9" with a previous cam/engine combo and power brakes, wipers, and headlights worked OK, no issues.
Old May 28, 2017 | 02:30 PM
ykf7b0's Avatar
ykf7b0
.510/.510
223/235
108 LSA
Who is selling this cam for a sbc?
Old May 28, 2017 | 03:20 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Visit Straub Technologies... http://www.straubtechnologies.com/custom-camshafts/
