I have a 76 stingray, it was starting fine and now when I try I just get a click. Battery is good, starter is good, all fuses are good. I changed the plugs, oil, valve cover gaskets and now it wont start. very frustrated, any help would be great.
Start here.
Check that the cables at the battery are clean and tight.
Check the negative from the battery to the frame (under the car and about under the battery) is clean and tight.
Check the positive cable at the TOP solenoid is clean and tight.
Check the ground cable from the starter to the frame is clean and tight.
