4-speed hard to get out of reverse
Old 05-27-2017, 10:50 PM
JER BEAR
JER BEAR's Avatar
Default 4-speed hard to get out of reverse
small block 73 hard to get in an out of reverse,no problems 1st 2nd 3rd an 4th
Old 05-28-2017, 12:25 AM
ddawson
ddawson's Avatar
Recheck the shifter alignment.
Old 05-28-2017, 07:02 AM
68notray
68notray's Avatar
And clutch pedal adjustment too. Reverse is unsyncronized so if the shafts are spinning at all reverse would grind
Old 05-28-2017, 05:02 PM
terry82
terry82's Avatar
like others have said I would check the linkage .But I also would change the fluid to synthetic.
Old 05-29-2017, 07:49 AM
68notray
68notray's Avatar
Not if it is a Muncie
Old 05-30-2017, 12:27 PM
JER BEAR
JER BEAR's Avatar
Thanks I,ll try both
Old 05-30-2017, 02:09 PM
jim2527
jim2527's Avatar
Check the column lock cable.... mine was kinking and showing the same signs. Poor shifting on and out of reverse.
grady white (09-18-2022)
Old 05-31-2017, 01:41 AM
rajin cajin
rajin cajin's Avatar
Could just be some crud between the levers. Might start by hitting the shifter levers with some WD40. I'm doing a frame off and the old grease between the shifter levers was like tar.
Old 05-31-2017, 10:40 AM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
most likely the interlock cable is cruded up, preventing smooth shift into reverse.
usually someone disconnects column interlock at the column , because they did't like it.
(if you do Not have to shift into reverse to remove your key, yours has been dissconnected.)
But the cable is left dangling and neglected, still connected to the transmission.
it cruds up, it will not shift into reverse.
Old 05-31-2017, 10:53 AM
4speeds
4speeds's Avatar
Hi,
You state " transmission is HARD TO GET OUT" of reverse. This means that obviously it goes into reverse OK but difficult to get out?
The most common cause in Muncie 4 speeds IS NOT linkage adjustment or cable issues. It's dampening springs under the reverse gear.
So rather than the "try this or try that approach", simply remove the linkage attached to the reverse shifter shaft and with a wrench on the shifter shaft see if the motion is fluid for the reverse to go in and out. If is it, then it is external to the transmission, if not, then it is internal.
Go to 3 minutes & 42 seconds into this video:
Old 05-31-2017, 12:03 PM
gerry72
gerry72's Avatar
That was a very informative video, 4speeds.
To 4-speed hard to get out of reverse
Quick Reply: 4-speed hard to get out of reverse
