1976 stingray corvette starter
Old May 29, 2017 | 03:20 PM
s1976's Avatar
s1976
1st Gear
Default 1976 stingray corvette starter
My starter will not run or make a click noise to indicate it wants to crank.
Old May 29, 2017 | 10:52 PM
ykf7b0's Avatar
ykf7b0
If your car is an automatic trans make sure the shifter is all the way up to engage the safety switch. It happens.
Old May 30, 2017 | 10:42 AM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome!
Is the battery good and are the cables connections clean and tight?
Does the horn, lights and other electronic work?
Stick or automatic.
Old May 30, 2017 | 11:33 AM
TimAT's Avatar
TimAT
Just to the right of the distributor on the firewall is the 6-way connector for the starter extension harness. That plug tends to get hot and corrode, that caused more heat and more corrosion. Good place to start any troubleshooting for starter problems.
Old May 30, 2017 | 05:57 PM
Snoopysvet's Avatar
Snoopysvet
Darn right it happens, I sat in a parking lot for 20 minutes one day thinking something was terribly wrong LOL!
To 1976 stingray corvette starter
