Freeze Plugs, pull trans or engine?
Old May 29, 2017 | 08:43 PM
shaggyd's Avatar
shaggyd
Default Freeze Plugs, pull trans or engine?
I just purchased a 1972 LS5 with a four speed. It's been in storage since 1981. I managed to get it running again but it's leaking (gushing) coolant from between the engine and transmission. I'm certain it's a freeze plug.
I've read the threads about changing the clutch on this car to get an idea of how difficult this fix would be. It seems changing the clutch is more difficult than other clutches I have done in the past. I'm wondering if pulling the engine might actually be easier.
I'm also planning on replacing the radiator as well.
Thoughts?
Old May 29, 2017 | 09:18 PM
rkj427's Avatar
rkj427
Pro Mechanic
Welcome to the forum!
Check out the C3 area for additional information on your questions.
Old May 29, 2017 | 10:48 PM
Moving this to C3 Tech/Performance Section.
Old May 30, 2017 | 08:53 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I would pull it since your pulling the radiator. the ease of doing repairs out of the vehicle has its merits. How old is the clutch, you could replace that while your in there. Be careful though, it could turn into while i have it out I'll replace the pan gasket, then onto the main bearings since I see them, well if I have that apart........ then it turns into a 383. So set some limits for yourself
Old May 30, 2017 | 09:05 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Pull engine. If those are bad the others will soon follow. Install brass ones and forget about them.
Fix all the little leaks....paint it up pretty.....
Then do like the rest of us and go down the "while I'm at it path" and change the cam, heads, pistons......
JIM
Old May 31, 2017 | 10:15 AM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
Hah ! That's just what I was gonna say ! Pull it, if one is bad , then ?
Old May 31, 2017 | 01:13 PM
Big2Bird's Avatar
Big2Bird
Jeese. Pull the tranny, change the plug and clutch, then drive it. The others are easy in the car.
To Freeze Plugs, pull trans or engine?
