Repro Inside Rear View Mirror Issues
Jun 1, 2017 | 12:06 PM
I recently bought a repro inside rear view mirror and the mounting tab is slightly thinner than the original which causes the mirror to move even when fully tightened. Anybody have a good solution for this? The only thing I can think of is to shim the tab or add same material to it and grind to proper size. Thoughts?
Jun 1, 2017 | 02:34 PM
Is the little square bushing, inside the hole in the mirror's mounting tab? Without that bushing, the mirror won't tighten up.
Jun 1, 2017 | 02:55 PM
Quote:
Originally Posted by
gbvette62
Ah! I now see the little square bushing in the old mirror. The new mirror did not come with that. Hopefully transferring that over will do the trick.
Jun 1, 2017 | 05:04 PM
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Neil B
It should solve your problem. I make that bushing...
and for a good reason...
Willcox
Jun 1, 2017 | 08:32 PM
Willcox Corvette
Willcox
That square bushing has got to be the smallest part on the whole car!
But it pops right out of the old mirror.
Jun 3, 2017 | 09:10 PM
Neil B
Yep. Should work. Note that my repo mirror did come with one, but was too short and did not work. A separate bushing did the trick.
