I'm finally ready to try the cam break in on this rebuilt sbc.
I filled the oil filter (PH25) and just over 4 1/2 qts in crank case.
The dip stick still at ADD mark. Using all orginal parts.
I think it will take 6 qts to come to FULL mark.
Is this too much?
Is this too much?
Have you oil primed the engine yet? If not, I'd do that first and check the stick again and add oil as needed.
SBC's take 5 qts with an OEM pan, smaller .5 qt filter for the cars! I use the SBC truck filter which is 1 Qt so my total capacity is 5.5 qts for a fill.....
