Misfire help needed
Old Jun 4, 2017 | 12:40 PM
The New Guy's Avatar
The New Guy
Cruising
Default Misfire help needed
Changed the oil pressure sending unit (not working). Now my OP gauge works but terrible missfire from engine. Checked all plug wires, cap, etc. and cant see anything wrong. Suggestions? By the way fuel pump power supply was rerouted by BUBBA prior to my purchase.=if that makes any difference.
Old Jun 4, 2017 | 05:06 PM
TimAT's Avatar
TimAT
What year? HEI? Points? DO the basic stuff first- make sure all the plug wires are on the plugs and on the correct plug.
Get a spray bottle, mix up a few drops of dish soap and water, then with the engine at idle, mist the plug wires from the cap to the plugs. If there's a problem with the wires, it'll show up.
Old Jun 5, 2017 | 10:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you checked the computer for an error code?
Old Jun 6, 2017 | 12:20 PM
gungatim's Avatar
gungatim
figure out which cylinder is misfiring first. pull off wires one at a time if you can't tell by sound. then work backwards from that cylinder. plug, wire, cap, rotor, etc.
To Misfire help needed
