I was finally able to start and drive my 1982 after a few months of working on it. Initially, all seemed well, but then I realized that it would die when slowing down. It didn't matter if the transmission was in N or D, so I was thinking it was vacuum related.
For fun, I tried disconnecting the EGR solenoid, leaving the vent open on the valve, and plugging the port on the throttle body. Problem has disappeared!
My question: Is EGR necessary on this car? What damage will be done if I continue to drive without the solenoid in place? How can I disable it completely? New solenoids are NLA and I don't think there is any other way of correctly hooking it up.
I've seen some use "block off plates" or something. Is that totally necessary, or is ventiing to the atmosphere accomplishing the same thing? I'm really surprised I don't have a check engine light from all this. I removed both AIR solenoids and the EGR as well!
No, the valve is still bolted in. I was just curious if there was a difference between leaving the valve in place disconnected, versus the block off plate option.
