Torque spec for '79 diff cover?
Old Jun 8, 2017 | 08:13 AM
Highlander1732's Avatar
Highlander1732
Default Torque spec for '79 diff cover?
Thanks in advance. I am buttoning up my 1979 diff to swap into my '75 after inspecting the unit and replacing the stub axle seals. Two questions: Can anyone provide the torque spec for cover bolts? And should I use a gasket and the Green permatex gear oil sealant or can i just use the sealant?
Old Jun 8, 2017 | 08:24 AM
fishslayer143's Avatar
fishslayer143
If memory serves, its 45 or 50 ft/lbs
Old Jun 8, 2017 | 12:19 PM
ddawson's Avatar
ddawson
50 ft/lbs
You don't need a gasket
Old Jun 8, 2017 | 05:33 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I used a paper gasket, torqued to 50 ft-lbs and filled. No leaks.
To Torque spec for '79 diff cover?
