Alignment shops in Monterey or San Jose area
I am willing to drive up to the san jose area as i have not had good results with the alignment places in Salinas. I recently upgraded to van steel upper control arms and their smart strut setup along with the borgeson steering box so I'm in need of an alignment. Any recommendation is welcome.
Bigeddie (06-09-2017)
i do have like a month before the car is back in the road so i will defiantly be taking my time on deciding where to go. I have been disappointed a few times here in my hometown.
if no or few recommendations..was my case..I had to interview the alignment shops..find a tech that knows vette 4 wheel, how to. but equally important is to research WHAT alignment specs you want to use for your car..and factory may not any longer be correct, depending on your set up, tires, suspension etc. Duntov in Texas has a chart..the reason you are not happy with prior "could be"..not the tech, but the specs. My car wandered til we got it right for the car..which started with research and ended with road test and a do over..the shop was willing to do that.
My problem was and still is finding someone that knows the vette 4 wheel alignment. i have done both stock alignments when suspension was stock and one one VBP specs when I had done the borgeson steering box(they didn't have any because their computer didn't go that far, should have been a warning). Now that i have upgraded some suspension I'm looking for somebody that can dial it in perfectly by doing exactly what you mentioned being an alignment then a test drive and a redo if necessary.
alignment
Santa Cruz Tire and Auto did mine. No complaints and seemed to be no big deal for them. They even gave me advice on the settings.
