Horn ?
Old Jun 18, 2017 | 09:32 AM
upnorth's Avatar
upnorth
Default Horn ?
Have had my 76 for around 30 years and can't remember if the horns has ever worked . Where do you start to try to fix them ?
Old Jun 18, 2017 | 09:53 AM
Highlander1732's Avatar
Highlander1732
North, I have the same issue. My horns on my '75 are "intermittent" and I don't think both are functioning. I'm sure others will share their advice, but as they are very easy to access from underneath the front valance (at least on my car), I would remove them and bench test by hotwiring them to a 12 volt source. If they both work, then I would check backwards from there. I "think" there is a relay along the driver's side inner fender near the firewall, but it may depend on the year of car? I would dig into the steering column as a last resort. Just my thoughts though.
Old Jun 20, 2017 | 09:25 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
run straight power to the horns themselves to see if they work. A friend of mine had non working horns and they were full of road dirt and bugs. After a lot of intermittent tries they finally freed themselves up. then check the power to and from the horn relay as well as the fuse
To Horn ?
