Holley Help !!!
Carb Gurus !!!A little backstory.....
I recently discovered that my Quadrajet has a crack in baseplate.
Which xplains my carb problems.
Anyway,
I got myself a Holley 4165(Spreadbore) 650 -CHEAP
and I'm stripping it down but wanna check I have all the bits
in my Holley rebuild kit (someone had previously opened it)
so some things aren't in their bags.
My question....
Can anyone identify this (Float) Needle and Seat Assembly ??
The needle is stamped 664. Nothing anywhere else
The new ones (from Holley rebuild kit) are stamped 515- I think.
I really need glasses LOL.
And are these the right ones for me...1974 L-82 350.
Thanks & Cheers,
Gav
Just kinda puzzled with these numbers.
Can't find any reference to them anywhere.
While I can't help much with the numbers, as long as you have the quadrajet replacement bowls, as opposed to the dual feed bowls, you should have a side hung, non adjustable needle and seat like this one https://www.summitracing.com/parts/h...FZWNswod0lcFmA
The primary assembly is .101 and the secondary is .110.
In addition there were many list#s for the 4165 series of carburetors so without that number nobody can tell you if it is correct for a 74 L-82. The list# is on the airhorn.
6210-3 and 2162.
Cheers
http://static.speedwaymotors.com/pdf/42506210-1.pdf
