Hey!
Need to replace the fuelpump of my L36 427ci. I can choose 1/4" or 3/8" for in- and outlet.
Do anybody know the stock size?
And are 8 psi and 110 gph too much for a 489ci stroker?
Neither. Factory pump would have 3/8 inverted flare (5/8 18). You can get an adapter fitting that would go from 3/8 male npt to female 3/8 inverted flare
Thank you!
About the fuel pump. Stock gph is about 30. I have a 489ci stroker and need a pump with more gph. The aftermarket are also available with 80gph and 6 psi. I think the 80 gph are enough. So would the 6 psi be better for the Q-jet?
