tach ground...?
Old Oct 1, 2002 | 08:01 AM
OkeeGuy's Avatar
OkeeGuy
Default tach ground...?
i was told that because my tach is jumping around that i have a bad ground...
what are the possible locations of such grounds that may effect this and where do i find them?
Old Oct 1, 2002 | 09:58 AM
Fleetwood's Avatar
Fleetwood
Default Re: tach ground...? (SIGNGUY)
Your tach shares the same ground as the dash lights,there are 3 wires on the back of the tach,it should be the black one.Do you have a tach filter,if not that can be the cause.
Old Oct 2, 2002 | 08:39 PM
OkeeGuy's Avatar
OkeeGuy
Default Re: tach ground...? (Fleetwood)
thanx...i was told by a guy that sells tach filters that they either work or they dont...
he said that if its acting wierd but working at all that its a bad ground???
Old Oct 2, 2002 | 09:15 PM
Twin_Turbo's Avatar
Twin_Turbo
The tach filter can simply be removed, it has a connector on each side, remove it and connect the 2 leads. You will probably notice the needle is actually pretty darn stable without the filter.
Marck
To tach ground...?
