Why 2" exhaust manifolds
Old Jun 27, 2017 | 09:06 PM
Sweet's Avatar
Sweet
Default Why 2" exhaust manifolds
Why did GM change from the 2 1/2" ram horn exhaust manifold they used in the small block C2 to 2" ram horn exhaust manifold they used in the C3.
Old Jun 28, 2017 | 11:54 AM
MelWff's Avatar
MelWff
Not positive but typically cost, probably more applications were using the 2" size
Old Jun 28, 2017 | 12:43 PM
domenic tallarita's Avatar
domenic tallarita
The 2" and 2 1/2 " were both used and it depended on the HP of the engine and how much exhaust needed to get rid of. That's what I have observed.
Dom
Old Jun 28, 2017 | 02:11 PM
MelWff's Avatar
MelWff
The 2 1/2" ended in 65 from what I can tell. So the 327 and 350 from 66 through 70 with both the 350 HP and 370 HP used the smaller 2" so HP doesnt appear to be the determining factor of it's discontinuation.
Old Jun 28, 2017 | 05:05 PM
20mercury's Avatar
20mercury
Default Will the 2 1/2" fit on the 66 thru 70 heads?
Hope not hijacking here, but will the 2 1/2" fit on the 327 350 66 thru 70 heads? So maybe you could swap out to the earlier larger manifold assuming you could find and afford them? This would seem to be directionally better???
Old Jun 28, 2017 | 05:29 PM
jim2527's Avatar
jim2527
Yes they fit and reproductions are easily found.
Old Jun 28, 2017 | 10:34 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Interesting, 2.5" small block C2 exhaust manifolds,
do they dump/exit in same position as C3 manifolds ?
therefore you could use BB=2.5" C3 pipes on SB with C2 manifolds.
Old Jun 29, 2017 | 09:09 PM
redwingvette's Avatar
redwingvette
I bought a set of 2-1/2" manifolds for my 73 SBC. They fit fine and look good.
Old Jun 29, 2017 | 11:35 PM
GUSTO14's Avatar
GUSTO14
BB manifolds do not dump in the center like SB manifolds do, so the BB pipes will not match up.
Some of the vendors (Allen's is one) will bend up a set of 2 1/2" pipes on request to fit a C3 if you want to use 2 1/2" manifolds.
Also some of the C3's came with 2 1/2" pipes from just below the (2") manifold to the mufflers. You can just replace the short 2" section of pipe with a 2 1/2" section to have a complete 2 1/2" system with the correct manifolds.
Good luck... GUSTO
To Why 2" exhaust manifolds
