Wheel smoking
Old Jul 1, 2017 | 05:11 PM
croaker's Avatar
croaker
Default Wheel smoking
Newest failure right front brake. Car was pulling real bad when I took a spin. I turned around and headed home and, I could smell something getting hot. Hoping it's not the rebuilt Trans. Front wheel smoking by the time I got home. Wheel was binding and hot as hell so I started taking things apart. How do I check the hose for collapsing? I cracked the bleeder nothing seemed to come out. Went to the hard line connection fluid started dripping after it was almost totally unscrewed. One piston seemed to be cocked a little in the bore. I'm buying caliper and hose but, I'd really like to know what failed.
Old Jul 1, 2017 | 05:57 PM
SH-60B's Avatar
SH-60B
once the old hose is off you should be able to blow compressed air through it. If not, it's blocked by something, likely collapsed
Old Jul 1, 2017 | 06:16 PM
cv67's Avatar
cv67
St. Jude Donor '05
either caliper stuck or the hose neither one isnt a bad fix.
Old Jul 1, 2017 | 07:17 PM
JayRay's Avatar
JayRay
I had this happen to me on another car, Hot day and I caught every, I mean every red light on the way to my sons football game. Your pad is sticking and your brake fluiding is probably boiling. I have not had the issue since, just that one time with constant braking.
To Wheel smoking
