Broke Steering Column Internal Rack Today
Old Jul 5, 2017 | 02:20 PM
Street Rat's Avatar
Street Rat
Default Broke Steering Column Internal Rack Today
I've got an '81 t&t column. The rack for the key switch broke. Is this a hard repair? I plan on doing some searches and learn before I work on it. Simply want to know how tough it is?
Old Jul 5, 2017 | 02:54 PM
TimAT's Avatar
TimAT
No deal- other than you have to tear the column down to replace it, it's an easy fix. Last time I checked, the rack kit was still a counter item at most GM dealers. Read up on the how to with Jim Shea's steering papers.
You'll need a wheel puller and a lock plate compressor, along with a pivot pin puller. Your local auto parts store will probably have those in their tool loaner program.
While you're in there, tighten up and locktite the 4 screws in the lower tilt bowl. Save yourself a repeat visit.
Old Jul 5, 2017 | 03:26 PM
Big2Bird's Avatar
Big2Bird
Download the papers, and just dive in. I laid mine out on the bench in order. As Tim said, you want to locktite those 4 screws buried all the way in.
I bought the rack kit at GM, along with the new bearings and seals.
Figure a day to remove and tear it apart.
Maybe a day to repaint it, clean up stuff.
A day to assemble it, and a few hours to jamb in back in.
Lock plate puller is still made. Pivot pin puller, I made my own with threaded rod and a socket.
I would also change the turn signal switch while in there. GM still has it as well.
Old Jul 5, 2017 | 05:45 PM
Street Rat's Avatar
Street Rat
Jim Shea's papers are the cat's meow. Very detailed information.
I've used them before for simpler repairs on my column.
We are fortunate to have them shared with us.
Old Jul 6, 2017 | 05:48 AM
Street Rat's Avatar
Street Rat
I studied Jim Shea's papers last night. I also ordered some internal parts for the steering column and a lock pin puller. I've been into this column before. So I have most of the tools needed to get me this far. Car is going to be down a while as I have other repairs and upgrades to perform. I'm glad this happened in my driveway and not out on a drive somewhere.
Old Jul 6, 2017 | 07:29 AM
Big2Bird's Avatar
Big2Bird
GM still nakes the ignition switch/dimmer switch. I didn't replace mine, and they went out 5 years later. Had to pull it again. Just sayin......
Old Jul 6, 2017 | 07:47 AM
Street Rat's Avatar
Street Rat
Yeppers. I ordered one from an online GM dealer last night.
Did you get your fan controller hooked up Big? I'd be interested in how it turned out for you.
Old Jul 6, 2017 | 07:53 AM
Big2Bird's Avatar
Big2Bird
Yes. Works great, and looks almost like factory. I'll post some pics if you like.
Old Jul 6, 2017 | 07:55 AM
Street Rat's Avatar
Street Rat
I'll pm my email address to you. You can send them there. That would be great!
Old Jul 6, 2017 | 07:57 AM
Big2Bird's Avatar
Big2Bird
I'll do it today.
Old Jul 6, 2017 | 08:56 AM
MarkinSETX's Avatar
MarkinSETX
How appropriate. I think this is what has happened to my column also. My wife couldn't get the key to turn to off in our 81. After a lot of reading I grabbed all of the Shea papers and diagrams. I was just wondering if I had to pull the column to work on that part, and it looks like I do. I need to work on the tach anyway, so I guess I work on a few things while the column is out. I was worried about how intricate this all is but looks like the instructions are pretty clear and should be a straight forward job. Thanks to the forum for the guidance and Shea for the nice write up.
Old Jul 6, 2017 | 08:58 AM
Big2Bird's Avatar
Big2Bird
It's just one of those jobs you want to do once, and be done with it.
Old Jul 6, 2017 | 10:59 AM
Street Rat's Avatar
Street Rat
I found this link that has some great pictures and information...PDF file
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
Old Jul 7, 2017 | 09:13 PM
Cavu2u's Avatar
Cavu2u
That's a pretty good piece of documentation there. Thanks. I saved it to the library.
Although not Vette specific that I saw, it still appears well written and good photos.
Steve
Old Jul 7, 2017 | 10:36 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This file below may help you too... this will get you most of the way...
Then go to this thread and I've described at the bottom how to get the rest.. Sounds like you are ready if you have the pin puller... Just remember to remove the big spring and to unlock the tilt teeth so you can remove the lower hub. https://www.corvetteforum.com/forums...post1594954923
http://repairs.willcoxcorvette.com/w...n-pictures.pdf
Old Jul 9, 2017 | 01:24 AM
Street Rat's Avatar
Street Rat
I received my pin puller today. Can't get back on it until Monday. I still feel a bit intimidated but onward through the fog I guess.
Old Jul 9, 2017 | 08:27 AM
540 vette's Avatar
540 vette
Did you read Jim sheas papers? You didn't need to buy one. He outlines how to make one. A bolt, small 1/4 socket and some washers and it works great.
To Broke Steering Column Internal Rack Today
Old Jul 10, 2017 | 06:29 PM
Street Rat's Avatar
Street Rat
Yes Sir I did indeed.
Three documents and three pages of illustrations.
The tool was ordered prior to me reading the papers.
It cost me all of $6.00
Old Jul 10, 2017 | 09:29 PM
TimAT's Avatar
TimAT
Be kind to the pin puller, it may be tender. The one I have is a genuine GM "Spent-More",
(Kent-Moore) tool. And I'm really nice to it. No desire to dig a broken screw out of a pivot pin.
Old Jul 11, 2017 | 12:45 PM
Street Rat's Avatar
Street Rat
I ended up with a Lisle puller. I've had good luck with their tools. I'm going slow and easy on this job.
