Parking brake cable adjustment
Old Jul 6, 2017 | 02:58 PM
The Punisher's Avatar
The Punisher
Default Parking brake cable adjustment
I got my rebuilt trailing arms back and need to install the cable for the parking brakes on both sides. I have the new cable installed but it is loose. It will slip out of the holder where the ball on the end of the cable is. I looked on you tube and here for setting this up but couldn't find anything
Old Jul 6, 2017 | 03:12 PM
Tiger Joe's Avatar
Tiger Joe
you take the slack out of it by using the threaded adjuster at the end of the front cable. center of the car directly under the parking brake handle you should see where the front cable (coming off the brake handle) and the rear cable meet. should be a threaded rod with 2 nuts. tighten them up to take the slack out, should stop it from falling out
Old Jul 6, 2017 | 03:20 PM
TimAT's Avatar
TimAT
A page from the FSM
Old Jul 6, 2017 | 03:36 PM
The Punisher
Does anyone have a pic of the cable going through the white plastic guide?i want to make sure I have cable spring in the right spot
Old Jul 6, 2017 | 04:11 PM
DonnieP73's Avatar
DonnieP73
This is from internet as I don't have a photo stored from my 73.
Donnie
Old Jul 7, 2017 | 05:34 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
That picture is priceless. I couldn't find it when i was trying to fix my system. It would have helped as the PO had my spring on the wrong side and the e brake would alwys engage. Mine work great now. Good luck.
To adjust the easiest way I put my car in the air, disconnected the half shafts and turned each wheel individually to get the shoes adjusted out properly so they just started to drag. Reassembled everything then adjusted the nut buy the AIM insrtuctions. It didn't grab the way I wanted it too so I tightened it up a bit more , now they hold on steep hills
Old Jul 7, 2017 | 06:04 AM
Wee's Avatar
Wee
Make sure you get the tab bent over the ball at the end of the cable.....It should not pop back easy. It's also a real pain to get it bent over enough.
Brian
Old Jul 7, 2017 | 09:11 AM
The Punisher
Brian
Does the tab get bent over the spring too or just the cable
Old Jul 7, 2017 | 09:27 AM
Wee's Avatar
Wee
It should only go over the cable.... I just realized I have the spring in the wrong location.
Brian
Big2Bird's Avatar
Big2Bird
I have to add, adjust the shoes first. Tighten each drum up tight, then back off 4-5 notches. Factory setting of 6-8 is too loose. Make sure they don't drag. Then adjust the cable.
Old Jul 7, 2017 | 10:17 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
if either cable is stretched or too long, and you run out of adjustment.
you can make a 3/8" diameter sleeve/spacer a couple inches long and add to the main handle cable where it meets the rear cable,
this will push the rear cable forward a couple inches, and give you enough to properly tighten the e-brake cable assemble.
Old Jul 7, 2017 | 03:08 PM
buns's Avatar
buns
I totally agree with that.
And, to the OP, don't forget to burnish in the new shoes or they will never grab properly.
Old Aug 26, 2017 | 09:59 PM
78 silver 78's Avatar
78 silver 78
I have the same problem. I put a spring clip on the ball to stop it from falling out , then I could adjust the cable. That picture is great but the is a GM cable not the one we get from the venders.
To Parking brake cable adjustment
