LS3 swap
Old Jul 22, 2017 | 07:57 PM
keithl1967's Avatar
keithl1967
Default LS3 swap
Not sure if I am even truly considering, but I have a line on a great deal for an LS3. Complete motor, comes with intact harness and ECU.
I know I'd need a new oil pan and a swap kit for the engine mounts,
beside the cost of above, what else would I be looking at parts-wise (can I still use my stock Trans(TH350)?
Pitfalls?
Old Jul 24, 2017 | 08:37 AM
mobird's Avatar
mobird
Pitfalls?
The other big thing (besides wiring) is setting the car up for fuel injection. Best way to do it is to buy an tank that is prepped for fuel injection with an in-tank pump. There are cheaper ways, but they don't work as well.
You can use your stock trans with a flywheel adapter.
If you google "LS Swap C3" you'll find comprehensive threads with parts list.
Old Jul 24, 2017 | 05:10 PM
Neil B's Avatar
Neil B
You'll need motor mount plates and LS swap headers. You'll also need to modify the heater hose outlets on the water pump to clear the upper a-arm. LS accessory drive setups can also get spendy. You may need a radiator as well.
Old Jul 24, 2017 | 08:08 PM
keithl1967's Avatar
keithl1967
Thanks, guys...Just kicking it around...decided to pass...
Old Jul 24, 2017 | 08:46 PM
Tim 1973's Avatar
Tim 1973
some other things you have to deal with is, Tach, speedometer if you do not stay with the TH350. I'm using the batwing pan on my LS3 swap. Temperature and oil pressure sending units will also need to be dealt with.
Depending on where your engine trans sit you might need to change the length of drive shaft.
Take a look at a few of the ls swap threads, read them to the end to see if the first change did not work or fit and ended up changing the setup. i know i changed the first way I dealt with the water pump heater out / inlets.
Tim
To LS3 swap
