Question for Engine Gurus
Old Oct 2, 2002 | 08:58 PM
ksbunting's Avatar
ksbunting
Default Question for Engine Gurus
I am having my 68 L79 327cid 350 hp engine rebuilt by a local machine shop that has been doing this work for 28 years and was recommended.
My question is, I supplied all the original parts from GM and they are twlling me it will only have 10.25 to 1 compression (instead of 11to1) and will take 60 days plus $3000 to do.
Why is it that GM was able to build this motor and achieve certain results and specifications and that cannot be duplicated by a machine shop using the same parts, many of whihc are brand new from GM.
I don;t know anything about engine building so would appreciate some insight from those of you who do.
Something stinks to me based upon just simple common sense.
Thank you,
Old Oct 2, 2002 | 09:07 PM
Gordonm's Avatar
Gordonm
Default Re: Question for Engine Gurus (ksbunting)
Don't know about the compression but 60 DAYS. Why. It sure does not take that long to machine and build a motor. Is the 3000 just for labor or is that parts and labor. If just labor I'd go elsewhere.
Old Oct 2, 2002 | 09:11 PM
gearheadz's Avatar
gearheadz
Sixty days & $3K to rebuild a stock motor with OEM parts...that you're supplying???? :eek:
I did my '70 L46 350/350 with an established, high end, race shop that has TONS of business and it took 4 weeks and about $5000. That included all new parts and labor!!!! New aluminum TFS heads, new Comp Cams cam & valvetrain components, new forged OEM pistons, Air Gap intake, Demon carb....the works!!
The 10.25 versus 11 to 1 thing is baffling. If its built using OEM specs and parts it should match the original compression unless you're using larger chamber heads, different pistons or a thicker (much) head gasket.
Walk away!!!
Old Oct 2, 2002 | 09:12 PM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: Question for Engine Gurus (Gordonm)
Doesn't sound like a good deal to me. :nonod:
Old Oct 2, 2002 | 09:13 PM
Twin_Turbo's Avatar
Twin_Turbo
That does not sounds like a shop you'd want to go to.
60 days is insane. Also, if everything stays equal and only the bore is enlarged the compression should raise. If they deck the block, the compression raises also.
The only reason for a lower compression that I can think of right now is the use of cheap 4 dish cast pistons & thicker head gsaket.
Marck
[Modified by Twinnie, 7:33 PM 10/2/2002]
Old Oct 2, 2002 | 09:24 PM
Larry B.'s Avatar
Larry B.
I believe the original head gaskets were a shim steel gasket that is seldom used today. When it is replaced by a modern composite gasket the compression will be lower. Also, I believe that Chevrolet gave the highest figure for compression ratio and may have erred on the high side. You are really better off with the lower ratio considering the Gas we have today..I know it may sound great to have an 11:1 engine but it is really a problem unless you have access to some 100 octane fuel. Enjoy..
Old Oct 2, 2002 | 09:39 PM
Barry's70LT1's Avatar
Barry's70LT1
To Clarify: 327 Ci In
If you have dome pistons with 64CC stock '68 heads (1.94 or 2.02), steel head gaskets, then GM said that was 11:1...
Same engine with "flat top" pistons, then it was 10.25:1 compression.
Any other combination will result in a different compression ratio.
Barry
Old Oct 2, 2002 | 10:12 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: Question for Engine Gurus (Barry's70LT1)
The sixty day part is fine, dosen't mean they are going to take sixty days to build an engine, means they are busy and busy usually ( not all the time ) means they are half decent engne building shop.
The $3000.00 baffles me if yu are supplying the parts, way out of line :eek:
Old Oct 3, 2002 | 12:07 PM
Oldguard 7's Avatar
Oldguard 7
DONT WALK AWAY RUN AWAY. Rebuilding an engine is not dificult provided you have the correct equipment and a reasonable amount of intelligence.
$3000 and you are supplying the parts?
:eek: I wonder what theyre smoking at that shop.
Old Oct 3, 2002 | 05:15 PM
68shark's Avatar
68shark
My rebuild (same engine as you) was $2,200 CDN ( approx. $1,500 US)by Agostino Racing Engines (Forum sponsor and subject of a feature article in current Corvette Fever mag.). All parts needed for rebuild, including new hyper. pistons, boring the block etc. were included with the exception of the cam/lifters/timing chain that I had purchased. It also took about a month for the reason that Agostino is always very busy......
Your quote sounds very expensive for labour only and would recommend getting other quotes before deciding.
:cheers:
Old Oct 3, 2002 | 05:49 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: Question for Engine Gurus (68shark)
What kind of gas are you planning on using with 11: 1?
By the way, my rebuilt is taking just under 30 days for about $4K and $950 of that is labor. Compression ratio is going to be about 9.7: 1. 330 hp, 380 ft-lb torque.
I pick it up next week. :)
[Modified by OHSIXX, 4:57 PM 10/3/2002]
[Modified by OHSIXX, 4:59 PM 10/3/2002]
To Question for Engine Gurus
