Here's a new engine photo or two
Old Oct 3, 2002 | 01:50 AM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Here's a new engine photo or two
Here's a couple shots of the new engine. :reddevil
Now I just have to finish hooking it up and breaking her in.....
:U
[Modified by joeveto, 11:51 PM 10/2/2002]
[Modified by joeveto, 11:52 PM 10/2/2002]
Old Oct 3, 2002 | 01:52 AM
djlangford's Avatar
djlangford
Default Re: Here's a new engine photo or two (joeveto)
Ruh roh, the image links didn't seem to work :cry
Old Oct 3, 2002 | 01:56 AM
djlangford's Avatar
djlangford
Two questions (now that the links work. :chevy )
1) How did you like the intake engine-lift plate? I was a bit worried about putting that much weight on my intake (I've got a '84 BB).
2) those are some LONG plug wires! Did you have to custom make them?
David
Old Oct 3, 2002 | 02:03 AM
joeveto's Avatar
joeveto
Cruise-In V Veteran
Default Re: Here's a new engine photo or two (djlangford)
David,
The engine plate came from Summit. My builder told me it was the only way to lift the engine, as I could no longer use the old manifold loops that were connected to my old iron intake. Of course, using the accessory holes on the heads would have been okay. But that doesn't do well for leverage.
So I bought the plate from Summit, for $20, and it worked great. I didn't even need a load leveler, as I did with the old loops. My buddy and I lifted the engine by the front hole of the plate, and that gave us enough leverage to lower the engine in at a nice angle.
The spark plug wires are so long it's silly. I bought them from Advanced Auto parts. I don't know if they are ridiculous, or cool. I like the way they are hidden, but I have concerns about the way they are routed, and the potential for cross talk. On the other hand, with the way they are routed, I'm not worried about my headers frying them. This has happened way too many times.
Hope the info helps.
Old Oct 3, 2002 | 02:19 AM
djlangford's Avatar
djlangford
Very cool, I used the accessory mounts and a buddy that has some heft behind him (or is that in his behind :lol: ).
I think the plug wires look cool! I'm about to be worried about frying mine with my headders (guess I have to get the engine fired first!) Only a few more things to go! (isn't that ALWAYS the story!!)
Old Oct 3, 2002 | 02:52 AM
DMONSVETTE's Avatar
DMONSVETTE
Very nice engine. Is it a crate engine? Thanks for sharing the pics.
:cheers: :smash: :seeya
Old Oct 4, 2002 | 01:33 AM
joeveto's Avatar
joeveto
Cruise-In V Veteran
Default Re: Here's a new engine photo or two (DMONSVETTE)
That's my old engine. It's bored .30 over. I couldn't decide on the paint color, so after changing my mind a hundred or so times, I decided to go low profile.
Old Oct 4, 2002 | 08:02 AM
PatsLs1vette's Avatar
PatsLs1vette
looks good :cheers: now get it done and fire her up. :yesnod:
Old Oct 4, 2002 | 08:15 AM
foundvettelifeisgood's Avatar
The third shot down makes me want headers. Way :cool:
Old Oct 4, 2002 | 09:09 AM
QuickVet's Avatar
QuickVet
Default Re: Here's a new engine photo or two (foundvettelifeisgood)
nice. did you paint the valve covers?
Old Oct 4, 2002 | 09:18 AM
groovyjay's Avatar
groovyjay
Very nice Joe, looking very :cool: :cheers:
Old Oct 4, 2002 | 09:28 AM
Edzred72's Avatar
Edzred72
In the last pic, I see you caught the engine thief on film. :D :D
Good luck Joe... bet you can't wait to fire her up. For the benifit of the neighbors... do so with open headers!!!! :jester
Eddie
Old Oct 4, 2002 | 10:41 AM
vettedan's Avatar
vettedan
joeveto- Lookin good! How many horses?
Old Oct 4, 2002 | 11:01 AM
Fevre's Avatar
Fevre
:cheers:
They look so clean a purty when they go in fresh. Did you use a cherry picker or do you have an overhead unit?
Old Oct 4, 2002 | 11:14 AM
Guest
Guest
Posts: n/a
Default Re: Here's a new engine photo or two (Fevre)
Very :cool:
Old Oct 4, 2002 | 11:27 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
ZZ4???
Old Oct 4, 2002 | 11:52 AM
vettesite's Avatar
vettesite
Tasty!!! :yesnod: Enjoy.
To Here's a new engine photo or two
Old Oct 4, 2002 | 11:56 AM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
So cool!!!!!!! A new engine must be soooooo exciting, I wouldn't know. :(
Old Oct 4, 2002 | 02:07 PM
JCL's Avatar
JCL
Hey Joe. Long time no hear........Tis a "masterpiece" JCL :yesnod: :yesnod:" Have Baffles. Will Travel"
Old Oct 5, 2002 | 01:52 AM
joeveto's Avatar
joeveto
Cruise-In V Veteran
Jim! Holy cow! Where've you been? Steve and I were just talking about you, wondering where you were. Drop me a line.
As far as the other questions go:
I used a cherry picker.
The valve covers are painted silver. They were black originally.
This is not a ZZ4, it's my original block.
As far as horsepower goes, Similar combos built in Hot Rod and Chevy High Performance Magazine pulled over 400 hp at the crank. See Ryan's Engine Combo and Bible (?) Page, combo 99.
http://ryanscarpage.50megs.com/combos13.html
The above combo comes closest to what I have, except I'm running higher compression but stock Vortecs (not pocket ported). The compression came out, originally, to 10:1. I didn't want it to be this high, so we switched to thicker gaskets. This brought it down to 9.7:1. I should have no problem running 92-94 octane at this level.
Honestly, I'm figuring on around 280 at the wheels. If I can get this or higher, I'll be happy. What I pulled out of the car was a boat anchor. One of my heads is still frozen to my cracked intake manifold. There were so many carbon chunks and misc. crap around the combustion chambers and in the intake, anything should be an improvement. Also, I was running a stock converter before, and couldn't even chirp (let alone spin) the tires. Now I'm running a 2000 stall. So this alone should liven things up.
I'll let everyone know, once it's up and running. I plan to get those break in miles out of the way fast.
:cheers:
[Modified by joeveto, 11:55 PM 10/4/2002]
