Quick question: differential mount bushings
Old Oct 3, 2002 | 03:10 AM
jerryjfunk's Avatar
jerryjfunk
Default Quick question: differential mount bushings
... are called, "Pinion snubber cushions", right? If so, why are the poly ones cheaper than the rubber ones in the Zip catalogue? I always thought poly was better... is there an advantage to using the rubber ones here?
Thanks,
jerry
