oil fouling plug
Old Aug 4, 2017 | 11:32 AM
jvm's Avatar
jvm
Default oil fouling plug
on my 79 L82 I have the number 6 cylinder fouling the # 6 spark plug
don't think there are too many miles on the engine.
Options before I go with a new paint job and restoration????
Old Aug 4, 2017 | 12:37 PM
TimAT's Avatar
TimAT
IF it's an automatic, the vacuum modulator line enters the intake right at #6 cylinder IIRC. Bad modulator will allow the engine vacuum to pull fluid and it goes right to #6.
Old Aug 4, 2017 | 12:47 PM
jvm's Avatar
jvm
Forgot to add it is a 4 Speed
Old Aug 4, 2017 | 07:31 PM
sunflower 1972's Avatar
sunflower 1972
Bad valve stem seal? Here's a temporary solution:https://www.napaonline.com/en/p/NDP7302444
Old Aug 4, 2017 | 08:49 PM
tgcattle's Avatar
tgcattle
possible leaking intake manifold gasket
Old Aug 17, 2017 | 08:52 PM
LenWoodruff's Avatar
LenWoodruff
But that would be trans fluid correct? Would it still be oily black?
To oil fouling plug
