Wipers were working fine this spring. I was testing everything for a proposed trip and found they are not working now.
What I've tested so far:
- wiper cover system works properly.
- fuse is good.
- "kill" switch at base of column is good and in the on position.
- wiper cover switch, on fire wall, is good and adjusted properly.
- wiper switch is good.
I can hear the wiper solenoid "click" when I turn on the wiper switch but no action from the wipers happens. Not sure where to look next.
If your wiper door is working properly, the solenoid would have nothing to do with the electrical operation of the wiper motor. There have been recent posts regarding the viability of the wiper switch ground connection. I would do a post search for wiper motor.
