1974 engine noise
Old Oct 3, 2002 | 09:15 PM
Stingray1970's Avatar
Stingray1970
Default 1974 engine noise
Listened to an engine noise on a friends SB 4 speed. Everyone is telling him it's a rod knock, but I'm not convinced. Can't tell where it's coming from, but I think it's too tinny for a rod and there isn't a change in the noise when the plug wires are pulled one at a time. Had the v- covers off and didn't see any thing unsual. Looking for suggestions :crazy:
Old Oct 4, 2002 | 12:04 AM
no_radio's Avatar
no_radio
Default Re: 1974 engine noise (Stingray1970)
Do a compression test to rule out piston slap and valve train issues.
Alternatively, get a stethoscope and locate it that way. be sure to check valve lash.
Jeff
Old Oct 4, 2002 | 12:15 AM
Stingray1970
I forgot to mention this car has only 23,000 on it. My friend told me he had flooded it while starting it cold, he then started the engine and it had the noise.
Old Oct 4, 2002 | 04:18 AM
jackson's Avatar
jackson
Badly worn cam lobe on hyd lifter motor can mimic rod knock.
Old Oct 16, 2002 | 10:46 PM
Stingray1970
Default Re: 1974 engine noise (no_radio)
Found the engine noise tonight, number seven rod is bent, the noise was the piston hitting the crankshaft counterweights. It must have hydraulicked with gas.
To 1974 engine noise
