Window Stains
Old Oct 3, 2002 | 11:31 PM
Scudd's Avatar
Scudd
Default Window Stains
I have what looks like hard water stains on the rear window of my vette and have tried various ways to remove but have been unsuccessful. Any suggestions?
Old Oct 4, 2002 | 02:52 AM
paintdaddy's Avatar
paintdaddy
Default Re: Window Stains (Scudd)
I usually use the rain-x compound/cleaner and put their glaze/repelent over it .I have heard of using steel wool and,toothpaste.
Old Oct 4, 2002 | 03:15 AM
twotone82's Avatar
twotone82
Yeah, I know. It's acid rain etching. I had it on my windshield and mirror tops. Toothpaste and MAS glass polish does help a bit, but if the etching is bad, there really isn't much you can do (except a replacement). I just had my windshield replaced because I got a crack running from the top-corner passenger-side down (I have no idea where it came from). I had slight etching on it for the past 7-8 years or so. At night, on-coming headlights would make my vision a bit hazy. When it rained (God forbid), I could hardly see the road, 'cause the wipers weren't wiping a totally flat surface. Rain-X helps in a big way, but only temporarily (you've gotta keep applying it every month or so and it takes a bit of elbow grease to get a polish). Since I've had my windshield replaced, I'm loving night driving.
A professional glass shop may be able to help, but in my experience if the glass is etched, its probably better to just replace.
Good Luck,
Bill
[Modified by twotone82, 7:25 AM 10/4/2002]
To Window Stains
