Vintage Air install questions
Okay my car is a 69 convertible no A/C. My interior is compltely gutted and body off, laying down dynomat on the interior, DEI on the exterior and figured I would partially install the Vintage Air. My first of probably many questions is the side fresh air vent doors and cables. Right now they are still connected and laying there. With the new Vintage Air do I still need to keep them? Will the cables connect to the center console control with the new vintage air electronic control? I cant fins any mention of it in the instructions, just the caps to cover the other vents.
So anyone that installed this kit in a non A/C car did you just remove the cables and close the doors or keep the doors and cables and still able to use them.
Just finished my 69 convertible non/a-c. The cables aren't affected and will still operate. I asked the same question and the response was there is really no reason to remove them. I agree.
Thanks!! I searched the instructions and couldn't find any mention of them. Its good to know, I'll leave them on. Did you close the rear Astro vent? I know the front vacuum lines for the blower and stuff get replaced in the vintage air set up. Were you able to keep the vacuum for the rear Astro vent?
Yeah. I thought it was strange they didn't mention those also. Not sure about the rear astrovent. When you convert the control panel all the vacuum lines get removed. Guess I'll figure that out at some point. I just want cold air coming out the vents!!
