oil
Old Aug 15, 2017 | 09:58 AM
upnorth's Avatar
upnorth
Default oil
How much would the oil have to be overfill to make it start smoking . Reason i asked is i was a little low so i added some and if i jumped on it i got some smoke out of the passenger side . It seems to have stopped . I pulled the plugs on that side and they looked fine other then a ring of oil above the threads ( they seemed to be a little loose when i took them out )
Old Aug 15, 2017 | 01:34 PM
MelWff's Avatar
MelWff
2 quarts or more
Old Aug 16, 2017 | 03:05 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Loose can end up badly. Check the rest if you havent. They can shot out with force.
Is your dip stick reading incorrectly? You can change your oil, add the 5 quarts, run it for a few minutes to fill the filter then let it sit to get all the oil from the heads back in the pan. Then mark you dipstick
To oil
