What are the "must have" tools
The one tool you need is a bottle opener. After using it a few times a day everything seems better. :cheers:
A great set of sockets is a must but a second portable set is nice.
You MUST have , at minimum, a mini bar fridge :D
3/8ths drive extensions, ratchets, sockets... and a 1/4 to 3/8ths adapter
1/4 inch breaker bar... big monster ratchet, and a set of large shortie sockets
A FULL SET of standard hand wrenches if you can spring for it, go short, and long.
Adjustable wrench... a few of em, all shapes an sizes
Oil filter wrench... makes life easy changing the old dino juice out, for the new stuff
This looks like a nice kit http://www.sears.com/sr/product/summ...id=00933122000
Oh... 4 jack stands, a floor jack. dont get a bottle jack, a spare tire jack, get a floor jack 3 ton's is what i like. Lift most anything.
If you can spring for an air compressor... get one
Buy the BIGGEST box you can afford, and fill it up. TRUST ME i have a small set, that is all over the garage, because the box wont hold it all... didnt start that way.
Specialty stuff...
Distributor wrench
Pulley puller
Timing light
Torque wrench
Torch
I suggest getting all you can afford man... if the tool makes the job easier, its worth it. If it makes it take less time, its worth it.
Good luck in your wrenching... and dont forget the PB blaster penatrating oil. :smash:
ZD :cheers:
Get a craftsman tool! ALWAYS... or snap on or other great brand... because if it breaks, which they might... you can take it back, and no questions asked... get a new one!
