Small Block with Headers OIL FILTER
Old Aug 19, 2017 | 02:53 PM
ykf7b0's Avatar
ykf7b0
Default Small Block with Headers OIL FILTER
I have been using a standard oil filter for my small block but since swapping to headers it seems a bit long and too close to the header collector. What oil filters (brands with numbers please) are you guys using with headers on your small blocks? Thanks!
Old Aug 19, 2017 | 03:09 PM
keithl1967's Avatar
keithl1967
I use AC DELCO PF1218 on my corvette and camaro (headers on camaro, not on 'vette yet).
The 1218 is larger and has a bit more oil capacity, but if you have space constraints, you can probably use the AC Delco PF454, which I think is the small block recommended filter...check the cross reference for sure...
Old Aug 19, 2017 | 05:21 PM
Go-Gone's Avatar
Go-Gone
Just changed oil on my 69 that has headers and the PF 454 works fine
Old Aug 19, 2017 | 06:47 PM
BKarol's Avatar
BKarol
I use a K&N filter #2002 on my 78 and don't see that it is close to the collector.
The height is 4.6 inches whereas the PF454 gives their dimension at 3.2. The original 78 oil filter calls for a PF25 which I just measured at 4 inches.
Old Aug 19, 2017 | 10:27 PM
cv67's Avatar
cv67
St. Jude Donor '05
but Wix makes a tiny one barely a few in tall.
To Small Block with Headers OIL FILTER
