73 corvette starting problem.
Old Aug 20, 2017 | 04:53 PM
pa c3 corvette fan's Avatar
pa c3 corvette fan
2nd Gear
Default 73 corvette starting problem.
I just installed a new wiring harness under the hood of my 73 stingray. (csb) Using a volt meter I checked and I have electricity to the altenator, to the starter, up to the distributor cap, but the car will not start. It acts like the car is not in park. When I turn the key it does not crank. The lights work, the battery is good, just no start. A while back I changed the distributor from points to HEI. Any suggestions where to look for the problem?
Old Aug 20, 2017 | 06:04 PM
HUSKEE73's Avatar
HUSKEE73
check the neutral safety switch,if its and auto trans the switch is mounted in center console,and it is adjustable,worth a check.also look at starter switch on steering column,top side near firewall.
Old Aug 21, 2017 | 05:31 AM
pa c3 corvette fan
2nd Gear
Thank you for the advice Huskee73, I will check those later this week.
To 73 corvette starting problem.
