need to change differential cover
Old Aug 26, 2017 | 01:50 PM
ts_vette_st's Avatar
ts_vette_st
Default need to change differential cover
I pulled the spare tire carrier to inspect the tank and rear frame section. To my shock both lower tabs on the diff cover are broken. What is the best way to change the cover? Pump as much fluid as possible out, remove the bolts at the spring ends, drop cross member, remove spring bolts, remove top crossmember bolts, remove cover, replace gasket, put new cover on, replace top cross member bolts, replace spring bolts in diff, replace spring bolts on ends, replace fluid.
Am I missing any tricks or musts when doing?
Old Aug 26, 2017 | 02:31 PM
TimAT's Avatar
TimAT
It might be tricky getting to the upper mount bolts on the diff. And watch the length of the spring bolts that go into the rear cover. Sometimes they are different lengths front to rear.
Old Aug 26, 2017 | 02:38 PM
ts_vette_st
I think i am going to replace all the bolts too. Should i use grade 8 hardware?
Old Aug 27, 2017 | 06:16 AM
theandies's Avatar
theandies
I always error on the side of strength.
Old Aug 27, 2017 | 01:54 PM
ts_vette_st
Should I use locktight on the spring bolts into the cover?
Old Aug 27, 2017 | 02:39 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I have a nice dated 1974 rear cover in perfect condition available. $100 you cover shipping. Comes with all stock bolts for xmember and spring. Everything is perfect.
Old Aug 27, 2017 | 03:31 PM
ts_vette_st
what is shipping to 44667?
Old Aug 27, 2017 | 04:46 PM
63mako's Avatar
63mako
I will find out.
Old Aug 27, 2017 | 05:02 PM
63mako's Avatar
63mako
$18.85 shipping.
Old Aug 27, 2017 | 05:18 PM
63mako's Avatar
63mako
The differential is out of a 1974 and date coded. The cover looks to be an over the counter GM piece with no date code. I will include spring plate, still has visible GM label. Spring is 2 1/4. Looks like the last guy had the same issue you had and bought a new cover, bolts and spring plate. If you want it my Paypal is kevindjensen@sbcglobal.net I will cover fees if you don't feel comfortable sending Paypal friends and family.
Old Aug 27, 2017 | 05:23 PM
63mako's Avatar
63mako
That is it. Missed remove driveshaft to yoke bolts. it might swing down enough but doubt it. I think the strut rods and half shafts can stay hooked up. Torque bolts to spec.
Old Aug 27, 2017 | 06:15 PM
63mako's Avatar
63mako
Did some more research. This is a GM service replacement cover. It requires the spacer kit ($12) if used with the 2 1/4 spring. You can see it here, last item and in the diagram.
https://www.paragoncorvette.com/c-23...eaf-mount.aspx
They do use a smaller diameter bolt I am including so more meat on the outer mount area. Vent is in cover as well.
Old Sep 1, 2017 | 03:28 PM
ts_vette_st
Sorry was out of town for work and didn't get online. So $120 shipped with bolts, plate, vent, crossmember bolts? correct
Old Sep 1, 2017 | 05:50 PM
63mako's Avatar
63mako
Yes
Old Sep 1, 2017 | 06:37 PM
ts_vette_st
I will take it.
Old Sep 1, 2017 | 06:45 PM
ts_vette_st
PayPal says sent but I don't see the debit on my bank. Check it.
Old Sep 1, 2017 | 07:49 PM
63mako's Avatar
63mako
It is here. Will ship out tomorrow.
To need to change differential cover
Old Sep 1, 2017 | 09:44 PM
63mako's Avatar
63mako
It is a nice cover, no pitting. Packed up with vent, spring plate, spring bolts and crossmember to cover bolts. USPS Priority mail with $120 insurance. tracking #9405803699300499261258
Thank you!
Old Sep 1, 2017 | 10:28 PM
63mako's Avatar
63mako
Paragon photo in above link shows 7/16 flat washers against spring plate. There were no flat washers on this so you will have to get some.
Old Sep 3, 2017 | 05:45 PM
JayRay's Avatar
JayRay
Post up a thread on how this install comes along. I am procrastinating it even though I have the parts already. Would love to hear "finished it in a day", "Pretty straightforward" or "weekend project" Pics along the way would be awesome.
