This is Strange....
Old Aug 26, 2017 | 08:28 PM
smacota1's Avatar
smacota1
Default This is Strange....
1970 with automatic. This issue just came out of no where. When I turn my parking or headlights on the left blinker light in the speedo lights up and stays constant.
Using the turn signals, the light blinks as normal. All the exterior lights operate as they should as well as the emergency flasher.
Searching for any similar problem does not seems to give any clues.
Any tips for troubleshooting would be appreciated.
Old Aug 26, 2017 | 08:49 PM
'75's Avatar
'75
Sounds like a ground issue at the left park light, it's seeking a ground through the dash indicator.
Old Aug 27, 2017 | 07:30 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
i agree with '75. I had that same problem on the right side of my vette.
Old Aug 27, 2017 | 11:02 AM
smacota1's Avatar
smacota1
All,
Thanks for the suggestion. Now I have a starting point to explore.
Old Aug 27, 2017 | 12:55 PM
carriljc's Avatar
carriljc
Start by looking at the lit up parking lights and tail lights. See if one is a lot brighter than the others (could be associated with an oddball filament contact issue). Anyway, make note of that, eyeball the lamps to see if you can notice anything abnormal, and replace them anyway.
Light them up again and see if it made any difference. If good, ok, if not, then troubleshooting can continue from there.
Old Aug 27, 2017 | 08:52 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The light on the dash will always tell you which side your issue is on too..
I'd check the parking lamp jumper harness.. They like to corrode at the connection between the jumper and the forward lamp harness.
Willcox
To This is Strange....
