I have a question about engine break-in with my serpentine system installed. My vintage air system says I souldn't run my Sanden (sp) a/c compressor without the A/C charged. So my question is, can I use a Sanden compressor that spins but is not in operational condition in the break-in of the engine until I am ready with my good Sanden and system for a charge? If yes, anybody know where I can buy a break-in donor? Appreciate any help you can provide.
David
The Compressor has a Clutch on it. There should be a wire going to the Clutch. Disconnect the wire and the Clutch can not engage. So the Belt and Pulley will be turning but not the Compressor.
No power to the a/c compressor clutch, the compressor is not going to turn. Unless the clutch is fubar.. But that's a different deal anyway. Throw the belt on and light it off.
