68 valve issue?
Old Aug 28, 2017 | 01:10 PM
RandyMack's Avatar
RandyMack
Cruising
Default 68 valve issue?
I have a 68 with 327/350 that I bought as a project two years ago. Engine and heads were rebuilt by the guy I bought it from. Finally got to the point of first start-up and I hear this clanking noise from valve covers. Take them off only to discover that in his haste to sell me the car he never tightened the rocker arms. So after properly setting exhaust and intake valves, I was able to get her started. Sounds great at idle and revving in my garage. Once I take it out and put it under load I get this popping and backfiring sound coming from exhaust, it seems. It's not backfing that I'm familiar with through the carb. So here's the question. Is it possible that I bent a couple valves on that initial first start up? And if so, how do I figure out which ones without pulling the heads? Thanks! Randy
Old Aug 28, 2017 | 01:24 PM
lvmyvt76's Avatar
lvmyvt76
compression check on each cylinder
Old Aug 28, 2017 | 01:48 PM
HeadsU.P.'s Avatar
HeadsU.P.
If you trust your skills on setting the valvelash properly you would not have suspected piston / valve contact. I really doubt that is an issue anyway unless a valve spring is getting lazy. Might be some wiped cam lobes though without knowing the history of oil changes involving zinc protection.
Most likely carb or ignition issues. But first, I would go back and double check the valvelash. Google which of the two procedures is comfortable for you: running or engine off. I bet a lot of the backfire goes away the second (adjustment) time around.
Hopefully its not dirty lifters that refuse to pump up. That would explain however, the loose valvelash from sitting.
Old Aug 28, 2017 | 02:42 PM
TimAT's Avatar
TimAT
It's really tough to get the valves and pistons to hit on a SBC. It can and has been done but it's not easy. I'd double check the firing order too.
Old Aug 28, 2017 | 09:04 PM
RandyMack's Avatar
RandyMack
Cruising
Thanks for responding. Issue was a simple one. Number 6 and 8 plug wires crossed. Running beautiful now. Whewwwww!
To 68 valve issue?
