T50 5-speed
Old Aug 28, 2017 | 06:34 PM
Dynra Rockets's Avatar
Dynra Rockets
Default T50 5-speed
Was looking at a local CL ad when I noticed the oddball T50 5-speed. Can't believe it is holding up as even the Monza V8 version was only good for 200 ft lbs.
Otherwise seems like a nice driver and with hardtop.
https://atlanta.craigslist.org/atl/c...282190274.html
Old Aug 28, 2017 | 07:25 PM
Crimson Thunder's Avatar
Crimson Thunder
I had two Monza V8's and both had saginaw transmissions. They were junk.
Old Aug 28, 2017 | 07:36 PM
Dynra Rockets
Saginaw was 4 speed. If a dog leg 5 speed then was the BW T50.
Old Aug 28, 2017 | 07:54 PM
Dynra Rockets
265 ci of lethargy
Yes, the 262ci engine was factory rated at 110 hp IIRC, which I believe was 5 more hp than the 3.8 V6.
With good mufflers and a Holley 390 it made nice noises but not a lot of thrust.
Old Aug 28, 2017 | 08:01 PM
cv67's Avatar
cv67
St. Jude Donor '05
i stand corrected 262....sounds like he pieced it together and is moving on?
Old Aug 29, 2017 | 10:17 AM
AboveTheLogic's Avatar
AboveTheLogic
That thing is tiny. I thought "T50" was a typo at first
Old Aug 29, 2017 | 12:11 PM
Crimson Thunder
Is the T50 the transmission that makes the 1-2 shift like a normal transmission would make the 2-3 shift?
Old Aug 29, 2017 | 12:30 PM
Dynra Rockets
Yes, hence the name "dog leg". Reverse is up to the left.
This pattern is an old school road racing pattern as you only use 1st to get out of the pits. 2-5 are what you use for fast shifting on course. Reverse is out of the way so do not accidentally select it. Many European cars back in the day used this pattern.
If I wanted this pattern I would adapt an old BMW/Mercedes Getrag instead of a T50. The T50 is very weak and no replacement parts exist. The only way I could see a T50 surviving in a C3 is if you got the weight down to 2900 lbs and had a mild short stroke 250 hp engine (ie 283/302/307) .
Old Aug 29, 2017 | 04:11 PM
Richard454's Avatar
Richard454
I saw that ad- being listed in Atlanta but car is in North Carolina. Too many red flags- sounds as though they put whatever was laying around the shop to piecemeal it back together. Looks good in the pictures BUT "needs" some work on the inside (no pics) and "trailing arm bushing has some slop in it."
Richard
To T50 5-speed
